jjj807
Hey guys,
My brother has a x4 955 system with a sapphire radeon 2GB 6950. He installed the latest drivers and says that the amd graphics overdrive in catalyst control is enabled. Should he disable this? He does not wish to overclock his graphics card, he is fine playing diablo the way it is now. What does the graphics overdrive do? Sorry, been away from ATI CC for awhile.
Thanks
***UPDATE*** HAVING problems:
Thanks for the reply guys. He says after an extended period of diablo 3 say over an hour or so, the screen splits in half and it appears to be rolling over from one side to the other? Everything works, nothing is frozen but the screen is flipped/split and when he restarts his computer it goes back to normal. This happens when both graphics overdrive is on and off. He has the current version of Catalyst 12.4 and even rolled back to 12.3, same problem. The card is a sapphire 6950 factory oc 2 fan model, with a core clock of 820mhz, he scaled it back to 800 in amd overdrive to see if that was causing this and it still happened. Any ideas what this could be?
System is x4 955 not overclocked, 8gigs ddr3 1600, antec earthwatts 650 psu, asus m4a79xtevo mb, windows 7 64-bit. Acer 22 inch monitor 1680 x 1050 resolution
Worried his power supply may be the culprit? Its a solid unit that powers a 6950 in one of my friends systems just fine. Idk
Thanks in advance!
Thanks
Thanks in advance!
