R9 280X + FX 6300, decent combo?
lehtv
11,897
74
2560x1440 is 78% more pixels than 1080p which makes it that much harder to run the game at fluid framerates. In order to do that, you need to back down on image quality settings, which brings back much of the CPU dependence that was gotten rid of when increasing the resolution. In CPU heavy games, an FX-6300 can still bottle neck a 7970 situationally, not to mention a 290X.
AtenRa
14,003
3,362
Thats why i said to get the R9 290X, he could play the majority of the games at 1440p on High or Ultra settings at 60fps.
lehtv
11,897
74
Can you tell me what you mean by "that's why"? It's not very clear to me. It seems like you're saying "because of FX-6300 bottlenecking at 1440p, I said to get the R9 290X, he could play at 60fps". Contradiction.
escrow4
3,339
122
Going to pick these up in under an hour. Yes I could slap in a new 30" monitor but this current U2412 is more than enough for me. Right now, I'm just getting those 3 parts.
ElFenix
102,405
8,580
save the $80 and get the xeon
:thumbsup:
el etro
1,584
14
I think all of those combos listed will be awesome:
FX-4100 plus HD 7770;
FX-4350 plus HD R7 260x;
FX-6300/6350 plus HD 7950;
FX-8350 plus HD 7970 Ghz;
4.5-5Ghz FX63xx plus R9 290x;
FX-9590 plus HD7990.
Z15CAM
2,184
64
www.flickr.com
Whatever be prepared to repair a NO Dead Pixel QX2510 1440P 120Hz Samsung PLS Display for Back Lite-Bleed @ $300. NO Dead Pixel is a HOAX.
Whether you see Back Lite Bleeding or not. De-Bezel 3 of them and mount them any way you want.
Back Lite Bleed is an easy Fix for an Enthusiasts.
escrow4
3,339
122
AtenRa
14,003
3,362
It is very simple, at 1440p and above we are heavily GPU limited. By using a higher performance GPU like the R9 290X, it will allow you to have 60fps at 1440p with higher Image Quality. Thus putting the weight to the GPU again and not the CPU. That is because we want to have 60fps.
So, with the R9 290X he can even use Quad Core CPU and still be GPU Limited.
toyota
12,957
For 1440p and above with a single GPU a heavily OCed CPU will only get you 1-2 FPS in the majority of the games. Have a look at ATs 1440p review.
creating a gpu limited situation does not mean that a faster cpu will not help if you are adjusting your settings trying to get a certain framerate. in other words I could crank every setting and get 30-40 frames in some games or I could lower some settings to try and keep me over 60fps. well I cant stay above 60fps in some games with my cpu at stock speeds.
escrow4
3,339
122
Didn't bother with a 290X due to price. If its 600-700 in the US it will be 800+ here and I will not pay more than 500 max for a GPU anymore here (Australia) even though I have the cash. Just seems pointless to me. Case in point, cheapest 770 = $465, cheapest 780 = $854. This 280x cost me $399.
