R9 280 vs GTX 960 - better choice?
el etro
1,584
14
Pick a R9 280, GTX 960 will get limited by its 2GB vRAM very, very soon.
SPBHM
5,076
440
280 is superior overall I think, the extra vram is nice but the 960 will be a better match for the i3, for the power efficiency and better CPU usage
jpg
jpg
http://www.eurogamer.net/articles/digitalfoundry-2015-nvidia-geforce-gtx-960-review
JDG1980
1,663
570
Friend is building his first PC and a $200 or less GPU is his budget. He's narrowed it down to these two, but trying to decide on which to get. What say you guys?
It depends on what he plans to do with his system. If he's going to be focusing on hardcore gaming (1080p or above on high detail settings), then the R9 280 is probably a good bet. However, if he's primarily interested in productivity apps and has a multi-monitor setup, then I would suggest the GTX 960. This is because AMD video cards use considerably more power than their Nvidia counterparts when running multi-monitor, even when they're idling on the desktop. Also, the GTX 960 has a better port layout (three DisplayPorts).
If he's going to be gaming at 1080p and isn't insistent on the absolute highest detail setting for everything, then either of these cards would be fine. In that case, which one he chooses depends on whether he values power efficiency (GTX 960 is far more efficient) or cost (R9 280 is about $30 cheaper).
If he's insistent on the price point but wants a hardcore gaming card, he might want to look for a used Sapphire R9 290 Tri-X on eBay. He should be able to get that for $200 or so. Although the AMD Hawaii architecture isn't as efficient as Nvidia's Maxwell, it provides a lot of raw power. This should be good for up to 1440p even on relatively high settings, except perhaps for the worst programmed AAA titles.
kantonburg
2,975
kantonburg
2,975
He's not a hardcore gamer. His price point came from what he'd spend on an equivalent XBONE or PS4. So he's also looking at that graphically speaking. He knows by building a PC he's got room to upgrade and room to grow that you don't get with a console.
garagisti
592
7
IMHO, buying a 960 when one can possibly buy a 290 for a few dollars more, is very questionable, unless power and heat are a major consideration even over performance. I would recommend 970, but you can get a 290x cheaper, nevermind 290, so that's a no-go unless you pay Nvidia specific games mostly. FWIW, it has already been advised that you could and should check out used forums. Both here and even fleabay if you're feeling a wee bit adventurous for a 290 preferably with an aftermarket cooler. If that makes you feel a bit worried, then signup for mails on Newegg and they will let you know of deals. There usually are 2-3 good deals a week or so.
Happy hunting.
SimianR
609
16
The 960 is not by any means a bad card. It's just that the R9 280, 280X and even sometimes the 290 can be found for really great prices right now and they all offer better long term value than the 960.
Erenhardt
3,251
105
101
280 runs games with settings that 960 can only dream of. Tahiti is much more powerfull core with tons of compute in it. Extra 50% of video memory helps too, almost every recent game requires more than 2GB of VRAM @1080p. And if you are overclocking, boy, oh boy those 900 MHz is low :) 30% performance increase from overclocking 7950 is not unheard of.
kantonburg
2,975
There sure isn't one convincing argument over the other here :D
I will say I doubt power consumption will be an issue. I am surprised how much more the AMD draws over the GTX though.
kantonburg
2,975
Happy hunting.
I've contacted a couple of guys here in FS/FT. I don't know if he'll buy used, but I'm definitely going to when I upgrade. Can't beat the value.
Gikaseixas
2,836
218
Another vote for 290, so much more horsepower for a little more money
You can't beat that. If it's performance you're looking don't get the GTX 960 or R9 285, two bad releases period.
RussianSensation
19,458
765
A typical agenda driven answer, you have dozens and if not more posts attacking a card (960) sorely on price.
Wrong. I have not recommended 2GB cards for at least 12 months now unless they are unusual circumstances (i.e., 750Ti for a user with a low PSU). If you have followed my posting history closely, which clear you have not, you would have seen I voiced concerns about 2GB of VRAM even when 770 2GB came out, well before we even knew what Maxwell was. Already back then I advised gamers to pick up HD7950 B 3GB over 760 2GB and 7970Ghz/280X over 770 2GB. But you do not see the 2GB VRAM issue because all you see in my posts are some "AMD agenda." Similarly unlike your buddies at ABT mis-predicted, I actually bashed the 285 for high price, low VRAM, and low price/performance. This of course makes common sense to people who follow my posts because I could care less about a crappy AMD product (or NV product) and I'll call it out. You've been hanging around ABT for far too long and those AMD-shill/marketing campaigns by that site's owner have gotten to your head.
Yet remained a blind eye when the r9 290x launched at over 550+ ,plus the mining tax. That cost was supposed to allow suckers who had 3 generation old card to upgrade indefinitely!
I will address the misinformation you made in steps:
1) 290X cost less than the $650 780 and 290X outperformed it, while having more VRAM to boot. GTX960 doesn't cost less than an R9 280X and has less VRAM. Therefore, the implied comparison in how it relates to this thread is already way off base. From a price/performance point of view R9 290/290X were better than 780 but GTX960 is worse in this metric than an R9 280X or R9 290.
This bring us to point #2:
2) I do not recall recommending 290X and I specifically made many references to how it's an overpriced and irrelevant product when R9 290 came out at $399. Again, you don't remember those comments for some reason.
3) I do not recall myself recommending R9 290/290X at mining inflated prices if those prices resulted in far worse price/performance compared to 780/780Ti. You literally just made that up. Not only that, I actually recommmended that people NOT buy a reference R9 290/290X and that they should wait 1-2 months for after-market cards to come out, unless they were willing to get an after-market cooler/AIO CLC installed. By late spring/early summer of 2014 when after-market R9 290 cards fell to $350-375, of course I started recommending them over $400-450 780 3GB, $550 780 6GB and $650-700 780Ti (when looking at dual after-market 290s). All of this is just consistent with me recommending price/performance. Price/performance isn't a biased metric as you tried to paint it in your response by attacking my recommendations as "agenda."
I don't need to step away from my computer at all to recognize, blind deceptive facts.
Blind facts?
I provided a review that clearly shows that a $190-200 R9 280X that was linked in this thread is faster than a GTX960. There are also already games that I wrote about which run worse with 2GB of VRAM. It is also a fact that an after-market R9 290 is on average approximately 45-50% faster than a GTX960. So far it is you who has just called out my points as lies but provided no legitimate rebuttal against my points. Instead you chose to attack me.
One has to wonder why you don't ever follow your own advice. 1:) Help AMD to increase market share...
Yet another clueless comment. In a thread where a poster created a poll asking what card we would buy assuming "all things were equal" between AMD and NV, only then I said that since I want more competition, I would choose AMD to get market share to 50/50, after which point I would flip a coin. If you don't agree that having 50/50% market share in the GPU industry is healthy, that's fine but don't call me biased for wanting that. Since not all things are equal (perf/watt, perf/mm2, compute performance, VRAM, price/performance, absolute performance, features), I do not only buy AMD cards as you seem to insinuate -- and that is because I am not blindly biased. Ever since you've joined the forums I have seen you purchase a total of 0 ATi/AMD cards. I have purchased and recommended a lot of NV cards over the years.
2:) to upgrade to current generations to mine coins and upgrade for generations to come forever....FOR FREE!.
Mining has not been profitable for a long time now. While it is absolutely true that I could upgrade to new GPUs for my lifetime for free with the money I made from mining, what is also true is that I instead converted my coins to USD and transferred to my bank account to spend on things that matter A LOT more to me than videocards, such as sports, travel, higher education, etc. So really you made a point about nothing there.
Because you can't, a strawman argument. Because that was all emotion driven BS.
You missed 4-5 years of mining, not me. We have plenty of examples of people getting 2nd and now 3rd generations of videocards for free from mining funds. I don't need to prove anything to you. I know each of my 7970s made me 4 figures in profits after all electricity expenses. Also, there are plenty of legitimate reasons why I am still on my 7970s such as having a large backlog of games that 7970s are good enough for, playing at 1080p, and not seeing anything that met my criteria for 75%+ faster performance increase on a per card basis. Of course since you only selectively read my posts, you would have missed all those points that I've made over the years.
Report the post. And then explain why AMD has to drop prices launched over 2 years ago to compete with current tech/features.
Wow, it's like you just built your 1st PC. Both AMD and NV drop prices all the time depending on competition. That's how the GPU industry works. I guess you completely forgot $650 -> $499 GTX280 or $650 --> $499 GTX780?
AMD owners validated their own purchases will dismiss these key features to feel better about themselves, except for the ones that payed 500+ for them used or new and then needed water blocks, cooling system to do what Maxwell does stock.
Huh? A lot of people on this forum who paid $500-550 for 7970s or R9 290 cards did so knowing those were not great price/performance deals but because of mining it didn't matter. Others waited until prices dropped. There was a clear distinction on this forum when it came time to recommend a card for gaming vs. mining in terms of price/performance. Secondly, considering 7970Ghz smokes a 680 today in almost every modern title, in hindsight even at $500 it was a better product without mining. In today's recent titles an after-market R9 290 also smokes a 780, 7970Ghz approaches a 780 and 290X is tied to a 780Ti. Of course if one waited 6 months and got an after-market R9 290 for $350, it was a better deal than buying a new R9 290X for $550. Who is arguing that R9 290X at $550 was a great deal at launch? :hmm:
Technically you could run an R9 290, but they are mostly 280-300ish.
If the budget is strict <= $200 the option is basically an R9 280.
1. You can find an XFX R9 290 for $255 at NCIXUS.com. That's up to 45-50% more performance than a $200 GTX960, double the VRAM, and lifetime warranty, all for $55 more.
2. A Sapphire R9 280X was already linked that is $190 + $4 shipping after $10 off coupon that ends by the end of the month.
It's interesting how you state that GTX960 is quiet but other cards are loud, instead of 960 is very quiet while other cards are louder, they are still quiet - which is actually the real truth about after-market R9 280X/290 cards.
You linked R9 285 which is slower than an R9 280X and way slower than an R9 290. Also, saying extra VRAM is nice is completely different from saying that 2GB of VRAM is insufficient for modern games if you want good performance. It's not "nice" as in it's a check-mark, but it actually matters.
Yes, it is true that i3 will bottleneck AMD cards in some games but once 2GB of VRAM is exceeded, you will have to drop settings in every modern game that relies on higher resolution textures. Since R9 280X and R9 290 are faster than a GTX960, the difference in FPS in those cases where the i3 bottlenecks will be less than what you showed.
Future games will become even more pixel, shader, texture, memory bandwidth and VRAM demanding. R9 280X and R9 290 will pull away from the GTX960 even more.
OP, if your friend hasn't purchased that i3 yet, tell him to spend a bit more and get an i5, even if it means going with an R9 280X over the R9 290.
If you don't mind looking in the used card market and can't quite stretch it to the R9 290, HD7970/7970Ghz cards often go for $120-140.
An i3 with the 280?, waste of time, get the NV with lower directx overheads!
Right, way to ignore that R9 280X is also within budget, as well as R9 290 is $50-55 away for a massive jump in performance and 4GB of VRAM that will give him a safe peace of mind for 2 years. Do you honestly think 2GB of VRAM is going to cut it when we already have 2014 games that show it's no longer enough? That's why GTX670/680/760/770/285/960 2GB are dangerous buys today for 1080P gaming for anyone intending to keep his/her card for 2 years.
You need to stop with the excessive arguing and YOU WILL NOT be using the word shill here anymore either.
-Rvenger
Reactions: Grazick
SteveGrabowski
9,367
8,054
jpg
jpg
Yeah, as much as I hate the 960, it's the obvious choice to pair with an i3. That video at the Eurogamer link you posted showing a piece of crap GTX 750 Ti outperforming an R9 280 in combination with an i3 in COD AW was a pretty damnjng critique of AMD driver overhead. With an i5 or better nothing makes any sense in that price range other than the R9 290 at $240, but with an i3 you're basically stuck between choosing a GTX 750 Ti, GTX 760, or GTX 960. I hate recommending the 960 because it's so underwhelming, but i3+AMD makes no sense when the i3 can't keep up with the driver overhead.
RussianSensation
19,458
765
From the same review they show you can have games where NV performs worse with an i3.
jpg
The OP needs to ask his friend if his friend will upgrade the CPU or the GPU in the next 2 years? Is his friend willing to sell the i3 today and go for an i5? If the OP's friend saves another $50-60 in the next 6 months, sells his i3 and buys a used i5 on eBay, then all of a sudden he would get that full 45-50% increase in performance over the 960. We don't know if the OP's friend is willing to spend extra $ today or in 6 months though.Also, does his friend use mods of any kids for games like Skyrim and upcoming GTA V? If so 2GB of VRAM becomes an even bigger issue.
I don't think the situation as clear cut as saying an i3 will bottleneck the AMD cards in all games equally bad. An after-market R9 290 is as fast as GTX960 SLI. Do you honestly think an R9 290 won't provide any measurable advantage in GPU limited games like The Witcher 3?
Magic Carpet
3,477
234
I know the R9 has 3GB vs 2GB on the 960.
The R9 is 384bit and the 960 is only 128bit.
The R9 is also cheaper.
He's using a i3-4160
8GB RAM
Thanks
If he intends to play latest games with the highest settings, both are bad purchases in 2015, imo. Tell him to save up more and either get an R9 290 or a used GTX 970 for <=$300. Problem solved.
Below is the Dying Light video memory usage. This is one clear example, where my card (GTX 670) is vram limited, waaay before gpu limited. I had to turn down textures to medium (to avoid slideshows) and even then vram usage hovered around the 2,000mb mark. 2GB is simply not enough today, even at a mainstream resolution such as 1920x1080. 280 is likely to fare better in vram limited games, though; but I'd still lean towards the newer, vram beefier and faster 290/970 cards.
bzb_Elder
87
15
This. To be honest, I stopped reading this thread about half way through. Seemed to turn into a typical AMD vs NV argument. I have to chuckle when I read these threads that say 3GB vram is required. As pointed out by JDG1980 and a few others, this really only comes into play if you (the gamer) wants the highest possible eye candy settings. With an i3 processor, this system isn't a serious gamer anyway (IMO), so I'd go with the cheaper of the two - find the best deal you can.
FWIW, I currently use a GTX 670 FTW with an Ivy Bridge i5 (mostly BF4), and I keep my settings on low / medium to obtain the maximum framerate possible. With that said, I set the in-game cap to 60 (59.95 I believe) fps and the game runs smooth as butter.
The title of this post should be changed to "Should I buy NV or AMD?" -- which is a question that typically results in arguments and insults. I think most people here would agree that the cards are similar enough that it's really not going to matter in this system.
Personally, I'm a bargain shopper. I'll buy the cheapest card that does "what I want it to do" - regardless of who the chip manufacturer is. I have one son running an R9 270x, and another who is still running a GTX570 - both on Athlon II quad cores -- and both systems are completely fine running modern FPS games.
kantonburg
2,975
He hasn't purchased the i3 yet, but right now that's in his budget. He's looking into upgrading to an i5 or even i7 (depending on price) around Black Friday or Christmas. Just swapping the CPU would be it for him at that point. He's looking at a 280 and I've shown him a used 280x & 290. He had me send message to the guys selling the 280x and 290.
Most of the time when a question like this is asked you can get a feel for which is better. This topic, however, is a different ballgame.
Headfoot
4,444
641
The price of the card defines whether its a good card. You can't separate them unless people are giving you one for free. The 960 is a terrible value relative to its competition (both other nVidia and AMD cards...) and thus a terrible card. If nVidia drops the price on it, the 960 could very well be a contender.
OP:
Keep trying to get those used 280x/290's. They are so cheap for so much performance it's insane. Used is definitely the way to go on a budget, IMO. Try and get a 290.
SteveGrabowski
9,367
8,054
What I think would make the most sense is buying the i5 right now and then buying a lower end GPU. Perhaps an R9 270 or hit eBay for a used HD 7870, HD 7950, GTX 660, or GTX 670. The reason I recommend this is GPUs don't hold their value nearly as long as CPUs do right now, so if your friend is upgrading in the holiday season that $300 he'd spend on an i7 could go to a high end GPU better than an R9 290, and his i5 would still be a top tier gaming CPU. Your friend would still be able to play games on medium right now and then have a really nice gaming system at the end of the year when he's ready to spend again. When buying for the future I think CPU should be the first buy, since in 10 months I doubt Broadwell or Skylake will be much better than Haswell while in 10 months it is likely GPUs will be significantly better for the money.
SteveGrabowski
9,367
8,054
But if you're buying GPU now then R9 290 is the obvious pick under the constraint of upgrading to an i5 or i7 later. It blows everything else out of the water at any price below $330. Pretty rare to get a high end GPU for a mid level price.
shady28
2,520
397
jpg
Really, you showed an individual frame from the video run?
That was from Assassin's Creed Unity.
Even the slower of the 2 960s beats both the R9 280 and the R9 285 at 1080p / FXAA on that game. These are the overall avg FPS:
Assassin's Creed Unity, High, FXAA
960/ 960 / 760 / R9 280 / R9 285
43.0 47.7 32.3 41.7 32.9
From the article :
"Of the nine titles tested, there are wins for the GTX 960 in just four titles (ACU, COD, Tomb Raider, BF4), while the R9 285 wins four (Crysis 3, Metro Redux, Shadow of Mordor, Ryse) and the R9 280 emerges triumphant on Far Cry 4. "
Kinda puts all your fear-mongering into perspective. Or should, if you were objective.
I should point out that the authors statement that the R9 280 won in Far cry 4 - from their own benchmark table - is incorrect. The R9 285 beat the R9 280 by almost 20%. And that's at 1080p / Ultra / SMAA.
What all these testers and most of the posters here fail to factor in is the texture compression that exists on both the 960 and the R9 285. You cannot just compare physical VRAM size or raw memory bandwidth anymore.
