- Sep 3, 2008
- 28
- 0
- 0
Well i've gotten my qx9650 @ 4ghz (10x400fsb) and it fails prime after only a few minutes. Really looking for help to keep it at 1.36vcore by getting some help with GTL Ref voltage settings because I dont wanna go over Intel spec and heard these help a lot.
Voltages from the bios readings are:
Vcore: 1.36v.
Cpu Pll: 1.61v.
Fsb Termination: 1.344v.
Dram: 2.11v, 4-4-4-15 Timings, 1:1 divider.
NB Voltage: 1.488v.
SB Voltage: 1.104v.
SB 1.5v: 1.55v.
Never Messed with these voltages:
Dram Controller Voltage Ref: 1.056v.
3.3v: 3.26v.
5v: 4.944v.
12v: 12.15
I have read that people have gotten a more stable overclock out of messing with the CPU GTL Voltage References, NB GTL Voltage References, AI Clock Twister and AI Transaction Booster settings. I have those all set to auto right now and was wondering if someone can give me some advice as to what I should try setting these at.
Also I have my FSB Strap to NorthBridge set to auto, should I just leave this alone or change it, what should I set it to?
Any and all help greatly appreciated
Vcore: 1.36v.
Cpu Pll: 1.61v.
NB Voltage: 1.488v.
SB Voltage: 1.104v.
SB 1.5v: 1.55v.
3.3v: 3.26v.
5v: 4.944v.
12v: 12.15
