Originally posted by: Fallen Kell
lol...
Let me know how that cooler works out. I have a HTPC, but I have one which actually fits a 120mm fan on the rear exhaust. Only problem is I can't fit the MONSTER towers in it because the placement of the CPU socket and the side wall will not let any overhang occur (and on some the heat pipes hit the support bracket for the top of the case). Right now I have a Ninja in it, and it does and ok job... would like something that would fit a little better and be just a quiet (I have 3 fans in the system 3 S-FLEX-f 120mm fans (2 under volted, the other controlled by the CPU pin)).
I will post here to this thread or PM you but I am a couple of weeks away before I start my two new builds and am waiting on a few components to become available.
For an HTPC you might also look at this one:
http://www.nexustek.nl/NXS-LOW...cm-high-CPU-Cooler.htm
