SolMiester
The Gigabyte GTX580 windforce is near enough to silent, though its 3 slots!
Keep in mind, if all you are concerned with is idle noise levels, the benchmarks for reference coolers online are not the lowest you can go. For all NV and AMD cards I buy, I lower the idle fan speed way lower. You can go all the way down to 15-20%, while stock fan BIOS speeds are often 35-40% (such as for GTX470/480 cards for example). I am not sure if they are also 40% for GTX580 card, but they are for sure much higher than 15-20%.
The point is, you can manually force the fan speeds of most cards far lower than factory default settings. This makes your comparison harder because I haven't seen any review site actually do this.
You would be fine with a Gigabyte 580 triple-fan (dual-slot). It will run pretty cool and quiet even at stock, so you should have plenty of room for adjusting the fan speed in MSI afterburner to make it even quieter, and possibly mod the BIOS to accept lower idle RPM if idle noise is an issue. Personally I'd recommend against GTX 580 though, the Gigabyte 570 gives nearly as good performance at $150 less. Once NVIDIA Kepler is released you'll probably only see the reference cards at first which are going to be loud in comparison to a triple-fan Gigabyte.
Not sure I follow. It seems to be a high-performance last hurrah for the 580, not a quiet variant. Or did I miss something?
Do you actually notice the difference in noise between 15% and, say, 30%? Cos my 560 Ti cooler stops making audible noise at about 35% fan speed.
