I just built a system and I like my silence or at least as much as possible.
Intel P4 3.0ghz 800 FSB
Antec 1080 AMG plus Case
Intel D875PBZ motherboard
I need to get a quieter fan/heat sinc than the one the proccessor came with.
I've heard the Zalman is the way to go. Is that the consensus? And what Zalman model do you recommend ( CNPS7000-Cu ) ?
also i need one more quiet 80mm fan. Would a Zalman fan be a good solution ?
thanks
thanks
