Originally posted by: morulis
I want to buy a MSI NX6800GT graphics card. I want to buy also a case (with PSU included) which can supply my graphics card and to have low noise(under 20dB). Any suggestions? Thank you.
Originally posted by: wisdomtooth
, rubber washer mounts for drives, etc.
Then you want to put in a QUIET power supply, and Silent PC Review recommends the Seasonic line of PSUs as the lowest-noise measured. You want a Seasonic S12-500 if your 6800GT card uses a 6-pin PCIe power plug.
You also need to quiet your video card by getting rid of the stock cooler and get a quieter one (Zalman VF700 or Arctic Silencer), a quiet CPU fansink (Zalman CNPS7000 or 7700), a quiet northbridge cooling solution
HTH.
Since you want such low noise levels, you need to get a steel case with implements for quiet components (120mm case fan mounts, rubber washer mounts for drives, etc.). Look for an Antec SLK-3000B-- It has those things.
You also need to quiet your video card by getting rid of the stock cooler and get a quieter one (Zalman VF700 or Arctic Silencer), a quiet CPU fansink (Zalman CNPS7000 or 7700), a quiet northbridge cooling solution, quiet case fans (aforementioned Nexus, Yate Loons, Panaflos, etc).
HTH.
Originally posted by: Kensai
Buy an Antec combo.![]()
Originally posted by: reader850
With the same goals in mind, I picked up an Antec TX 1088 today. It is one of Antec's new line of cases, complete with the new design TruePower 2.0 480 watt power supply, which has the latest connectors and two 12 volt rails. It is quiet, too. $139 for a top quality case and power supply seemed pretty fair to me.
