vbuggy
I'm tossing around the idea of building a home PC again. I have a rather noisy (to ears used to the HP Z800, Dell Precision T7500 and Mac Pro in a home setting at least) gaming rig based around a Lian Li X2000, i7-965+stock HSF, Corsair 1K modular, dual 295's and a quad-Vertex array (so at least we know HDD noise is not the issue).
What I'd like to do is to replace / rebuild this with an i7-980x based build, probably with an Asus P6X58D Premium, one HD5970 to start with (possibly two if I think I need it), also highly likely keeping the Vertex array (+ LSI Megaraid adapter).
This will no longer be just a gaming PC but an all-purpose machine to partially replace notebooks I bought as DTR's but are not quite working out (Dell Precision M6500 Covets with i7-920xm's) due to lack of absolute power, as well as a couple of other problems (so are partially being replaced with HP Elitebook 8740w's).
One of the key requirements of this, which is part of the reason why I tried going all-notebook, is noise. I'd like the resulting PC from the build to run as quiet as possible on air. Now I know even fairly carefully crafted DIY's aren't the quietest machines around and if, for example, I can't achieve the same quietness as an HP Z800 at the baseline, I'd probably look at buying a single-hexacore HP instead of going DIY.
Any suggestions for good looking, easy to build, roomy cases, fans, etc given the above requirements? Or am I better off going HP?
Thanks
Thanks
