Vbuggy,
What do you plan to do with this workstation? you stated that you are not planning to play games but did not state the intended purpose. I ask because of the video card which you are getting which is an unusual choice for a workstation. I usually get a fire pro or quadro for CAD...most people look at shaders etc. and claim that they are the same as consumer grade video cards when they are not ( I have run them side by side on similar systems and found them inadequate)
Cheers
I think I made it quite clear in the original post:
"This will no longer be
just a gaming PC but an all-purpose machine to partially replace notebooks I bought as DTR's but are not quite working out due to lack of absolute power"
But having said that, it has to balance power with silence - because one of the reasons I switched to an all-notebook setup was, as I also said in the original post, due to the silence - unless I crank up the gaming rig. Which I like. No longer will I have multiple, stuffed-to-the-gills workstations at home.
There will be CAD/Visualisation, there will be games, there will be Photoshop, there will be nooding in audio programs. As I said, all-purpose. The CAD products won't have certain optimisations but I'm not overly concerned - I'd just like to be able to do some semblance of work at home with a decent amount of speed. For anything really in-depth, I'll drive to the office. Some of the visualisation stuff actually scales in Crossfire (but chokes in SLI) so in one way it does make more sense to go with ATI.
In this scenario, to me a top-tier consumer card makes more sense - correct me if I'm wrong.
EDIT: Thanks for all the advice - I really appreciated it, but in the end I've decided not to build this time around and go HP. Many thanks once again.
