quickest way to lose a gut?
rh71
52,844
1,049
Originally posted by: smc13
there are two ways to lose weight. It isn't magic. Eat less and/or exercise more. I would argue that an anaerobic workout (lifting weights) is better for buring calories than an aerobic one but both work.
weights better than aerobic stuff ? I want to hear more...
I can tell you this - riding a stationary bike for about 30 minutes for me burns 300+ calories. Does lifting with rests for 30 minutes really burn that much ?
smc13
606
Originally posted by: getbush
Running is mostly anaerobic in the first few hundred meters. It takes a time for the aerobic pathway to get activated up to speed. As you workout more and more your anaerobic will last longer (more glycogen stores) and your aerobic will kick in faster, so you won't die before you get your second wind. This is also why you don't want to run and then lift weights. You will have depleted your glycogen already, and your muscles will have less to fuel the lifting.
If you are trying to do anaerobic running workout why not just do sprints?
Kaido
Feb 14, 2004
51,743
7,307
cool. the apartment I'm moving into has both a pool and workout room with bikes and all that.
getbush
1,771
My point was that running is considered aerobic excercise, but it does have an anaerobic element to it. I had 30 minute runs in mind.
ponyo
19,688
2,811
work manual labor in some sort of construction. guarantee you'll lose pounds all over.
smc13
606
Muscle burns calories even at rest. You will burn more calories doing the actual exercise if you do an aerobic workout then if you an anaerobic one. However, if you build up muscle mass you will burn more calories over time (The article says that for every 1lb of muscle you burn 50 calories a day - I think it less but who knows)
lavagirl669
3,325
Originally posted by: hytek369
Originally posted by: shaddupfool
lyposuction.. however u spell that
lypo is the probably quickest
yes, but if you don't exercise and diet it will come right back.
I know a girl who did lipo on her face and chin/neck, paid 10K for it
and she looks no different now less than a year later, than she did before
she did it.
Point is, she gained it right back because she doesn't work out or eat right.
SludgeFactory
2,969
Originally posted by: ElFenix
it will make the stomach muscles bigger, so, while you wait for the fat on top of them to burn off (in whatever order mother nature intended, so you might lose back fat or butt fat or wherever else first) your stomach will look bigger
not appreciably, there simply isn't the potential to add enough muscle there to have that effect. Bodybuilders have tiny waists despite training their abs to death.
OP should be working his abs, just like all his other muscles. The 4 inches of flab sitting on top is far more of a problem than whatever fractional size he might add via muscle. If anything, working the abs will probably help him subconciously hold his stomach tighter during the day and show less of a paunch.
If you really want to lose an assload of weight, do what somebody else said and get a heavy manual labor job, go dig ditches or work at UPS. It's like doing cardio for hours a day.
iwantanewcomputer
5,045
Originally posted by: gotsmack
does running burn more carloies than jumping rope? if so is it a lot more?
depends on how hard you run and how hard you jump rope. both are similar muscle strain, so whatever keeps your heart rate higher longer. i suggest running cause jumping rope is tough on the joints and boring for 30 min to an hour
Xaekai
82
The absolute quickest non-surgical method I've found is a dose of 65mg of MDA and 80mg for MDMA and then dancing to industrial techno for hours and hours.
revnja
2,864
You are so very cool...
