Quick question: Thermal paste required for AMD 4400+ installation??
DingDongDaddy
Just bought an AMD 4400+ & ASUS A8N5X MO. Opening the AMD instructions, the manual says thermal paste is required on all AMD processors. I did not realize that I needed thermal paste when I ordered the rig. To further confuse the issue, the AMD instructions do not show application of the paste on the picture diagram steps.:confused:
Do I really need thermal paste when installing the AMD??
DingDongDaddy
Sorry, I might be mis-reading the instructions. AMD says "thermal interface material" which apparently is on the heatsink that I have yet to install.
In this case I do not believe I need any thermal paste application? :roll:
stevty2889
7,036
8
The stock heatsink(which is quite good actualy) comes with the thermal interface material already on it, so unless you remove and re-install the heatsink, you don't need to get any.
Mogadon
739
But make sure you remove the little piece of plastic protecting the thermal interface material before you install the heatsink ... ;).
