My understanding of the rules for Cat 5/5e/6/etc cabling is that the max distance between two devices (a switch and PC, for instance) is 100 meters. From previous posts on this board, people have said you are allowed 90 meters of solid copper cabling (obviously puched down to patch panel/keystone jacks) with 5 meters of stranded patch cable on each end.
If 1 end only requires 1 meter of patch cable (for instance, if a 24-port switch and patch panel are adjacent in a rack), are you allowed to use 9 meters on the other end?
Also, if you are not using any solid cable (if two devices are in the same room) can you use a 10 meter patch cable?
I'm guessing the answer to both of these is yes, but just want to make sure...
