Quick question: can you fit two MCR220s (mounted on edge) and a PSU in TJ07's bottom section?
DerwenArtos12
4,278
Originally posted by: aigomorla
get the variable one.
The variable on setting 5 will = a DDC-3.2
The setting 4 wont. Having that lvl5 setting is just extra headroom incase you go more restrictive parts in the future.
Also, unless your based outside of cali, id go with one of the other vendors i recomended. Reason is the return and service on something if it goes bad. With the other vendors like jab-tech or petras, the store handles all the return for you.
I know Jab-tech will do the RMA for you if you bought the pump there. Should you ever need it. Or should it come DOA. [assuming YOU didnt break the pump]
As for that top piece dont bother, are you going 3/8id? Because 7/16ID tubing will fit over that pump outlet without any problems. Also 7/16ID masterkleer tubing is cheaper then 3/8id tubing. *shurg*
When are we gonna see that D5 top you've been promising. I'm not a very patient person and am getting tempted to try talking one of my regulars into wanting watercooling on his 6 month old quad set-up just so I have an excuse to check one out.
aigomorla
21,091
3,599
lol... then bug eddie and find out....
Eddie did say offically, EK is working on a D5 TOP.
The only ones out right now that i know of is the koolance one, but its nickle platted alu. And sorry theres no way in hell im trusting anything alu in my loops.
DerwenArtos12
4,278
Maybe I'll just bug one my customer that has a MCP655 variable to let me borrow it and just make my own top for it and send it to them for a prototype. You think martin would test it for me? I've got virtually no manufacturing capability but, once I had the patent i would open it up to anyone to build one for themselves or others so long as they make no proffit off them.
