DerwenArtos12
- Apr 7, 2003
- 4,278
- 0
- 0
Originally posted by: aigomorla
get the variable one.
The variable on setting 5 will = a DDC-3.2
The setting 4 wont. Having that lvl5 setting is just extra headroom incase you go more restrictive parts in the future.
Also, unless your based outside of cali, id go with one of the other vendors i recomended. Reason is the return and service on something if it goes bad. With the other vendors like jab-tech or petras, the store handles all the return for you.
I know Jab-tech will do the RMA for you if you bought the pump there. Should you ever need it. Or should it come DOA. [assuming YOU didnt break the pump]
As for that top piece dont bother, are you going 3/8id? Because 7/16ID tubing will fit over that pump outlet without any problems. Also 7/16ID masterkleer tubing is cheaper then 3/8id tubing. *shurg*
When are we gonna see that D5 top you've been promising. I'm not a very patient person and am getting tempted to try talking one of my regulars into wanting watercooling on his 6 month old quad set-up just so I have an excuse to check one out.
