Right now I recently purchased
MSI X470 Gaming Plus motherboard
I'm contemplating switching it out to a
MSI B450 Pro Carbon AC.
PRO Carbon AC has better features ( wireless, bluetooth etc.. )
Any reason to just stick with X470 vs getting the B450?
i paid 230 for my taiachi ultimate, I never even overclock, just rather have beefed up board since i will run it for 6 years most likely (will be gifted away at age 2).. but 60 bux is the only thing standing between you and the motherboard you want? 😉 just one time eating out is 60Taichi is like $170
Gaming plus $110
Pro Carbon is $110
AFAIK B450 Pro Carbon AC is pretty beefy I think rated one of the best b450 boards. Not sure i'll need all the features from the Taichi, but I did at one point consider it.i paid 230 for my taiachi ultimate, I never even overclock, just rather have beefed up board since i will run it for 6 years most likely (will be gifted away at age 2).. but 60 bux is the only thing standing between you and the motherboard you want? 😉 just one time eating out is 60
That's how I feel too. The value of the R5 1600 was incredible when it was released (remember, entry-level Skylake / Kaby Lake Intel quad-core Core CPUs were more expensive, and the R5 1600 is 6C/12T), even for $220, and now that you can get it for $80... hard to beat that crazy value.Was gonna go with the 2600 initially but it wasn't worth double what the 1600 was going for although it came with divison 2
yea temporary until ryzen 3.
16gb OEM B-DIE sammy was like 67 bucks shipped figured give it a go and see if it clocks well.
oh sounds great.. I like how you put B-DIE in caps 😉 where did you pick up the ram? any reason why you didnt rock the 2600k until the ryzen 3 comes? im sure the single threaded apps run faster for the most part on a 2600k
if planning on ryzen 3 seems like should buy a mobo for the ryzen 3 chip and not the 1600?
Picked up the oem ones on ebay. Its literally HP pulls that someone put up for sale and it still had the HP stickers on it. I could've rocked the 2600k longer until Ryzen 3, but the price drop of the chip of the 1600 tipped it over for me, not to mention the B450 Pro Carbon was in stock at the same time and the $30 promo applied when you purchase a chip and mobo combo O_O.
When I was pricing out the 2600 or the 1700 + pro carbon, the promo didn't apply and/ the mobo was always out of stock.
AFAIK the Pro carbon shouldn't have any issues running the latest chip from what i'm reading so if all else I'll pick up the newer chip and drop it in since it'll be supported.
there is more than 1 ram settings i hope.. a series of options that you can copy someone elses known working settings for same ram. my ram uses a xmp profile that is not for my ram im not sure why but after the newest bios it said a diff brand ram and model but the settings worked perfect. update to newest bios im sure will help.No i havent had to update my bios. and since these are OEM sticks it didn't actually any any xmp profiles on it.
I'll eventually update it but the only thing the bios update mentions is more processory compatibility, so not sure how that'll help me.
The motherboard does offer the memory try it feature and it's literally you choose the memory speed and the latency and this is what i'm running it at so far. Tried CL 14 but computer kept on restarting.
Search for the part number in ebay and you'll find a bunch. M378A1K43BB1
Also i haven't tried higher than 3200 yet, so i'll give that a go when i get a bit more time 😉
More info on the
I'll try some other memory settings before and after the bios update 😉
MSI Memory Try it
https://www.msi.com/blog/memory-try-will-boost-gaming-rig
no you search by the samsung number which i posted above.
M378A1K43BB1
If you google that part / model number you'll pull up the all the tech info from samsung in their docs it shows b-die.
reddit also is a good source 😉
Try it is there. I just didn't realize you can choose between the different chipset makers. So i'll double check I chose samsung 😉
https://www.msi.com/Motherboard/B450-GAMING-PRO-CARBON-AC
well i just spent 10 mins and read about your ram 🙂 here is what i got from it "just because it is B-die doesn't mean it does good clocks or timings. You can quite easily have 2400Mhz max B-die at like CL14 "
So OOPS i guess i am not exactly searching for Bdie but rather cl14 3200 rated sticks. If its worth the extra $$ is the question. I guess all the bios settings in the world wont help unless you go to 1.4v perhaps. Guess B die isnt as great as it sounds. The search continues.
