quick help formatting/reinstalling xp..
Chau
i'm trying to reinstall windows xp on my computer.. so i boot up with the xp cd.. and for some reason it lsits 3 partitiosn... (i have 2 hard drives i nthere), one partition is C:, and the other is D:, and then the other one is labeled "-:" and is 33mb... i select C: to install xp on that and then i press d to delete teh C: partition so that i can create the partition again and it'll format it.. but when i press d to delete the C: i get the following message:
Set is unable to perform the requested operation on the selected partition. This partition contains temopory setup files that are required to complete the installation
can anyone help please?
thanks
Originally posted by: waylman
just install on c: and mess with partitions afterwards.
would that just overwrite the windows files?? or would it format C: first then install xp?? i'd like it to be a clean install.. thanks
