Quick Guide to getting your 4850/4870 up to and running
taltamir
13,576
You might have heard that there are problems with the earliest 4850/4870, specifically heat and bugs... I put here a quick guide to getting up and running without any pain.
1. The driver. There were issues with the driver causing flickering in 2D. Those have been resolved, download v8.7 (or newer, 8.7 is current as of right now)
http://ati.amd.com/support/driver.html
Supposedly there are still still flicker issues if you use dual monitor and OC your card at the same time. There is no word about this as of right now.
2. If you have an early version, it will have a bios bug (or maybe it is a misconfiguration) preventing power play from working properly. Power play downclocks the GPU while it is idle to save power and make less heat.
You will need to flash the BIOS for this step (and only if you actually have this problem!), if you do not want to, skip it. The ideal way of doing step 3 also requires flashing the bios, the two can be combined into one flash operation (recommended).
MSI fixed powerplay BIOS for 4850:
http://www.techpowerup.com/vga...HD4850.512.080605.html
Sapphire fixed powerplay BIOS (so I hear, I didn't test it) for 4870:
http://www.techpowerup.com/vga...HD4870.512.080609.html
To flash it, I recommend using winflash:
http://www.techpowerup.com/dow.../Winflash_2.0.1.2.html
You should save your current bios somewhere safe
If the computer APPEARS to stop responding while flashing... WALK AWAY for 5 minutes... For me even the num lock and caps lock buttons were not responding (usually only occurs during a hard lock), and yet a minute later it suddenly started moving again and said flash successful... on a second flash it actually showed a progress bar the whole way through.
The correct operation for powerplay (on the 4850) is:
idle: 160mhz core
movie decode: 500mhz core
3d (game): 625mhz core
you can use the CCC to show you the current CPU speed.
3. The temperature. Like the 8800GT and many before it, the earliest units of the 4850 are simply running too hot. Never fear, there are fixes availble.
The best thing to do, is to avoid the problem altogether by buying a card with a larger HSF. Several companies now offer those.
If you already bought a 4850 with the standard HSF, then you should do something about it.
I prefer to take care of it permanently. If you are uncomfortable with BIOS flashing then read down... Since you are already going to flash to solve the power play issue, you might as well change the default fan speeds... It is a simple and harmless operation
First get Radeon Bios Editor:
http://www.techpowerup.com/dow...Bios_Editor_v1.11.html
Next, run it, use it to save the current bios somewhere safe.
Then select the MSI bios (or your own if it has proper power play) and go to "Fan Settings". Set whatever you want, I chose "Set all fan settings to recommended values". You can specify your own custom values...
You can also select the manufacturer code from a drop down list (msi, visiontek, etc)
save the modified bios to your hard drive, and then load it up with winflash from step 2.
There is always the option of putting an after market cooler, that would decrease your temperature so much that you will actually be able to overclock the card!
If you are uncomfortable with BIOS flashing, you can always take care of it in software. completely harmless and non dangerous (the process, if you set the fan speed too low it will overheat and might be damaged), it is limited to while you are in windows with this specific driver version... hopefully soon riva tuner will be updated for the 48xx and work with it, allowing you to set it in a the graphical user interface of riva tuner instead of having to mess about with settings files...
make sure your temps are below 90c load (ideally under 80c load) when you set the fan speed manually. If you set the speed too low and let it get too hot it can damage the chip.
Here is how to soft mod your fan speed:
Originally Posted by bretware
if you make a profile in catalyst after turning on Overdrive( make sure clock and memory settings are correct). You can then go to the file "C:\Users\Bretware\AppData\Local\ATI\ACE\Bretware. XML. the xml file will have the same name as the catalyst profile you saved. right click and hit edit.
<Feature name="FanSpeedAlgorithm_0">
<Property name="FanSpeedAlgorithm" value="Manual" />
</Feature>
<Feature name="FanSpeedRPMTarget_0">
<Property name="Want" value="0" />
</Feature>
<Feature name="FanSpeedPercentTarget_0">
<Property name="Want" value="65" />
Change the value to "manual" and Want value to "65"
Save the file then reload your profile in catalyst.
65% seemed perfect for me, 70% was loud but you may need it if your case has poor air flow.
You will have to select the profile everytime you start the computer, but it will work until there is a fix or better info so i can figure how to change the auto target temp.
Good Luck ,bretware
After that, you need to go into the CCC, and "unlock" overclocking, don't actually overclock anything, just click the unlock button.
This will solve all the problems with the earliest units of the 4850. Later units should not need any of these operations, but for us early adopters, a little work is usually required. Enjoy your new purchase and the best bang for the buck card out there at the moment.
:beer:
EDIT: I added the 4870 bios and modified the text to fit so that this guide is now fitting for both cards.
EDIT2: http://www.asus.com/news_show.aspx?id=11871
Every ASUS EAH4800 Series graphics card will also soon be equipped with the Glaciator Fansink
ASUS Announced a 4850 with 3rd party cooling. It should solve ALL the issues discussed in this thread, if you don't want to mess with it, buy that, or a similar card instead.
As I predicted all those problems are solved with improved models. They actually skipped steps compared to the 8800GT solving method and went straight to the last and ultimate improvement... A 3rd party cooler.
Not available in stores yet, but neatly solves all the issues. Since the fixed powerplay bios has been out before that card, buying it you are almost certain to have it arrive with the fixed bios. And the 3rd party cooling solution means that problems 2, and 3 no longer exist. Less then a month after release.
lopri
13,310
687
Great and detailed guide. Though I'm not sure how many would be comfortable with flashing a video card's BIOS.
Qbah
3,754
10
Great info here :) One question though: I own a 4870 and the idle clocks for the GPU are also 500MHz. I'm guessing it's also a powerplay issue (80C at idle...). Do you have any information/workaround for this issue for the 4870 cards? Updated BIOSes? Also, I'm running the leaked 8.7s, no problems so far for me (checked The Witcher, Halo 2 so far... not much time atm :p ).
Elcs
6,278
How else can "Powerplay" be fixed? Is it a BIOS flash only?
taltamir
13,576
yea, at first I only included that, but then I added non flashing fixes for all the steps for those who prefer them.
@BTRY B 529th FA BN: Thanks. I wanted to consolidate what I learned, and what took a while of hunting to find out.
I didn't... but a quick search yielded this:
http://www.techpowerup.com/vga...0&interface=&memSize=0
I got my MSI bios and all the flashing tools from techpowerup... turns out they have a video bios collection page... I heard the sapphire bios if fixed, but I see all four dated 2008-06-09. So they appear to be the fixed version. RBE can take any of them and modify the "manufacturer" string to match your own manufacturer. I also read that the sapphire one has a fixed powerplay.
Please let me know if it works for you.
taltamir
13,576
http://www.asus.com/products.a...model=2314&modelmenu=1
Mem
21,476
13
I know some guys at OCUK forums that have got the first batch of the Asus 4850 1 GB cards here in UK(was about 2 weeks ago) unfortunately its on pre order again in the UK.
For UK AT members,
ASUS 4850 1GB @OCUK
PowerColor 4870 1GB@OCUK
taltamir
13,576
mmm, seems asus actually announced ALL their 4850 will transition to this new cooler. Even the vanilla 512MB non OC version.. (they annonced an oc verison of the 512MB and the 1GB version of the 4850 as well).
TheNiceGuy
1,569
So the Asus is the card to get!
How about for a vanilla 4850 512, with no OCing? Are these issues critical for that as well? The reason I ask is that the Asus is $50 more than other brands here in Japan.
Thanks for the info and heads up!
bryanW1995
11,144
32
I wouldn't pay 25% more for that glaciator heatsink asus card. It'd be cheaper to just buy a stock unit and get an accelero AND a fan, and that combo will keep your 4850 as cool as my 3870 while likely giving you a LOT of oc headroom (think 750+ without vmods).
Bad Dude
8,464
I have the Asus 4850, can the MSI BIOS be flash onto this card to fix that powerplay option?
Thanks.
TheNiceGuy
1,569
Cheers bryanW1995
would I also need to flash the BIOS? And I can't see myself OCing the card, to be honest.
Qbah
3,754
10
Will do, but who's this RBE person I should ask for the BIOS? Also, GPU-Z 0.2.5 (newest) shows my memory running at 1MHz... Yes, 1MHz. And the GPU at 900MHz :confused: Here's the screenshot:
http://img401.imageshack.us/my.php?image=gpuzme8.jpg
CCC shows other values though... Here:
http://img296.imageshack.us/my.php?image=ccczy8.jpg
EDIT: Btw that BIOS you linked, it's exactly the same version as mine, the version string is identical. Also the notes below it don't say anything about a 160MHz clock for any of the states... Strange.
eosmund
7
A friend of mine and I have found that if you have a dual monitor setup, with the MSI BIOS the default speed is 625MHz. If you enable Overdrive, the speed can go down to 160MHz, but the secondary monitor gets bad glitching on the lower half of the screen. I'm not too concerned about it, I adjusted the fan settings with RBE and the card stays cool enough.
DaveSimmons
40,730
670
This wasn't working for me until I realized the Catalyst Control Center lies about the default profile support: it shows overclocking at dimmed but enabled (checked) when in reality profiles are ignored until you click the lock button and say yes to the warning.
So if you follow the instructions and your temp stays at 80, make sure you've unlocked overclocking.
On my 4870, setting the fan at 30% dropped idle from 80c to 60c, and the case temp dropped 7c as well.
MichaelD
31,528
Do ALL HD4870s currently available have the same flickering bug and other issues? I'm looking at a VisionTek HD4870. Maybe I'd be better off not being an early adopter? Thanks.
taltamir
13,576
@TheNiceGuy: the 1GB asus ones are safe right now... but overpriced. And you probably do not need 1GB on a 4850... Soon a 512MB version will be available. Look at the picture for the type of cooler it has, since it is missing the pictures of the asus one, I cannot tell you.
It isn't too hard to fix, but if you don't want to mess with it, wait another week or two.
@MichaelD: The flickering is a driver issue, not a card issue. You are gonna have to install a driver ANYWAYS, you might as well install the hotfix driver I posted here. You cannot harm the hardware by installing a different driver, so there is no risk!
There is nothing wrong with the cards causing the flickering, its a driver thing, and it has already been fixed. You just need to know about where to get it.
@DaveSimmons: thanks, I added it to the instructions.
@Qbah: RBE is a program (radeon bios editor), and I linked to it in this thread.
@Bad Dude: Yes, you can even use RBE to rename it to asus. You might not need to flash it though, make sure you actually have the problem first, if you do not then please use gpu-z to upload your unmodified bios.
@bryanW1995: me neither, but you are also paying for more ram... I except the price of a 512MB non OC version with the new heatsink to be the same or similar as the original.
fastman
4
1. The driver. the 8.6 driver causes the screen to flicker while in 2D, especially while scrolling.. It flickers quite often while in anandtech.com for me... So I recommend you don't use it...
The 8.6 hotfix is ideal, it keeps the stability of 8.6 while fixing the flickering... But for some reason AMD does not make it too easy to find on its website... however, a quick digging and I got the link:
http://support.ati.com/ics/sup...ledge&questionID=35298
Can you go into more detail about this flicker? I have an excellent alas old IIyama Pro 450 19" CRT. I have on a few occasions seen on my display what I would call shimmer across the screen upon first turning on the system! Nothing seems to correct this other then a re-boot and it's fine.
I have the 8.6 driver with the hot fix installed as far as I know. I did the soft mod fan mode too with excellent results, so the temps are fine.
But still have this problem?
taltamir
13,576
you know when you change the resolution it makes a click and the screen goes blank? Or no sound and just flickers black before changing to the other resolution, this is what I meant by flicker.
Also, I read somewhere that there might be a driver powerplay fix later. If that is the case I Was wrong about this being fixable only in bios.
Elcs
6,278
If that is the case, ill hold off doing a BIOS flash.
Originally posted by: Cookie Monster
Just when is the 8.7 going to be released?
Between July 1st 2008 and 31st July 2008. :D
So Id say in the next two weeks
