- Aug 16, 2008
- 86
- 0
- 0
I have a CM590 + Noctua NF-S12 1200 + Nexus D12SL-12.
They both come w/ the rubber screws.
I'm putting the Noctua on the side panel (lower slot), how do I install the rubber screws?
From the inside of the panel, through the fan, to the outside. Or from the outside of the panel, through the fan, ending on the inside?
Same would apply for the Nexus going on the top back hole of the case. Screws go from outside the panel --> in? Or from the inside of the panel --> out?
Tnx!
Tnx!
