Questions: What's so special about CULV?
Ika
14,264
I am sorry but you are flat wrong. This statement alone shows your ignorance. 17 watts for my LCD? My ass.
http://www.anandtech.com/mac/showdoc.aspx?i=3435&p=12
Here is Anand's own battery life test for the Macbook Pro. It uses a 50watt-hour battery and lasts 5 hours. That is a power draw of 10 watts. Last time I checked the Macbook Pro has an LCD screen. It also uses a regular core 2 duo last time I checked.
You can disagree with someone, but the word ignorance is a personal attack. These are not allowed here.
Markfw900 Anandtech Moderator
I'm pretty sure the reason the MacBook Pro has an LED backlit LCD screen. Those screens use less power than normal LCD screens.
Macbooks also have that nifty screen-dimming that they use after a short time. Windows7 has it too, but it doesn't work all the time (like with my GMA950 netbook - the screen just flashes black and doesn't dim at all).
aigomorla
21,131
3,667
*sigh*
Why dont you use Google and find out the answer yourself.
Infact here:
http://www.codinghorror.com/blog/2008/04/revisiting-how-much-power-does-my-laptop-really-use.html
the specifications of my Dell XPS M1330:
* Intel Core 2 Duo 2.0 GHz processor
* 2 GB RAM
* 32 GB solid state hard drive
* 13.3" 1280x800 LED backlit display
* NVIDIA GeForce Go 8400M GS video
* Windows Vista Ultimate
"How much power does the LCD display use?
LCD brightness 7 (max) 20w
LCD brightness 6 19w
LCD brightness 5 18w
LCD brightness 0-4 17w "
Lets even shrink that number for ya.
Your cpu can not be less then 5-7W on idle(which i doubt), that means u must have a super tiny LCD screen for it be only generating 10W.
Gillbot
28,830
17
Sorry Aigo, i'm calling shens on that article because I think the 20+W rating on a laptop HDD is quite excessive. I don't think they either know what they are measuring or thay's an OLD ass inefficient laptop.
EDIT: Here's another article with WAY different figures: http://www.shortship.com/articles/featured/16/laptop-power-consumption
and another: http://www.upenn.edu/computing/provider/docs/hardware/powerusage.html
Most show power draw levels at ~50w or LESS. I find it hard to believe that the LCD and HDD can use 20w each.
aigomorla
21,131
3,667
mmm okey....
take either or, however im still saying that his LCD alone would draw 17W.
17W on sleep with LCD off, i can believe, not with LCD on with windows desktop.
