- May 1, 2001
- 3,004
- 3
- 81
7/4/11
In the last two months Ive gained about 12-15lbs. Good, as thats what I was going for and definitely a lot more muscle. I am 511 and 217lb with 22% BF.
But .
1. Went from 2400 cal per day on cutting to 4300 cals per day. Well that was the goal.
2. Didnt maintain much discipline on the increased cal diet as compared to when I would be cutting. A) I usually didnt eat enough cals per day. B) When I did eat enough or go a bit over, Id have too many carbs and some days not enough protein intake.
3. Because of #2, I gained a bit of fat. I did a BF test, and my BF increased about 2-3% which is about 5-6lb of fat I added. So I added about 6-8lb of muscle which I definitely notice.
4. Sleep was/is still a battle. Many weeks of being sleep deprived and that would hurt the recovery time. I might have gotten 8+hrs of sleep 3 times in those two months.
5. I mostly did a 8x5(eight rapid reps times five sets with about 30 seconds reset in-between each set.) program of free weights with lots of compound movements.
Im a little worn out from the bulk routine of he last two months and starting to notice my face getting a little puffy again. No one else would notice but me. I want to start cutting and drop a bit of the fat I put on. I plan to go down significantly on carbs. I will be shooting for about 100 or less per day.
So my REAL Questions:
1. I want to get below 200lb. So what is the most efficient way to lose 20lb and maintain as much muscle as possible? Obviously keep on lifting, but not as hard?
2. Im not doing any aerobic now, all lifting. Do I scale back the lifting and add aerobic?
3 I feel like I should cut my losses and start cutting as I'm no longer enjoying the bulking phase? Would you say go another week or two? My BF is still awfully high.
Below is my post of 8 weeks ago before I started to bulk.
http://forums.anandtech.com/showthread.php?t=2161789
But .
