Hey all - I'm considering the Arctic Cooling accelero S1 rev2 or the Twin Turbo Pro to replace my (annoyingly loud) stock 4890 cooler. I'm not exactly an expert at messing about with aftermarket coolers, and was wondering if there was anyone, who had some experience with either of these coolers:
1. I see some people reporting, that they can't control the fan speed of the TTP with catalyst, although that should be possible, evidently - any experiences with that?
2. I've seen reports that the VRM heat sinks are terrible, which is why some people started recommending the Zalman ZH-RHS90. See for example:
http://forums.anandtech.com/showthread.php?t=307072
http://forums.anandtech.com/showthread.php?t=310039
Apparently it won't fit together with the Accelero (without some serious handywork) Will it fit together with the TTP? Or do I have other/better options?
3. Does the TTP need separate power for its fans, as in separate from the power supplied to the graphics card? I suspect this is a really stupid question, but I'm not really used to messing about with my PSU, and am worried that I might find it difficult. (The installation guides I've seen always seem to skip this point by just mentioning the 7V/12V adapter - which makes me think I'm missing something obvious)
I posted these questions in another thread, but the questions were probably going out of topic there.
Thanks in advance for any help!
