Questions about wiring a PSX dual shock pad on LPT1 and using a multi-meter...(need help/advice)
Currently I use two SNES pads on LPT1. It was not that difficult. I did not use a multi-meter or anything to see what wires were getting what, I just followed the diagram in Direct Pad. A website like myurl is very straitforward and easy to understand. For my SNES pads I used a crimp style DB 25 connector and soldiered the wires directly to it. I did not want to bother w/ any diodes. Both pads work great.
I'm very interested in doing a PSX pad [dual shock]. However, when I look at this site it makes the project of a PSX pad look a whole lot more complicated. Has anyone else w/out electronic experience (shy of wiring SNES pads) done this? It recommends using a multi-meter to check what pins are supplying what. I assume I can get that at Radio Shack, are they very expensive? Can anyone give me basic directions on using one or some links pertaining to that? Thanx in advance.
It's not as hard as you think.
The site you linked to has good pictures of how the diodes are installed,
but I would leave the leads a little longer and put heat shrink tubing
on them after soldering. Radio shack has the diodes, some are made with
a glass case and some are plastic. Go with the plastic ones, as they will
be easier to work with.
Are you going to use force feedback? From what I could see you only need
the power (and a volt meter) for that.
edit* Radio Shack has some small multi-meters for about $10.00 and they include instructions on how to use them.
Let us know how it goes!
