Raider1284
- Aug 17, 2006
- 809
- 0
- 0
Originally posted by: hsfnewbie
I'm reading up on that Swifttech 1x120 simple kit that you have posted. I'm waiting for the 2x120 but I have a related questions.
When I make my loop.. it's going to go from CPU -> VGA right?
1) Isnt the fluid coming out of the CPU going to be pretty hot by the time it goes to the VGA? Will this cool the VGA more than what air would do?
2) Do you think those Swiftech VGA RAMchip coolers are necessary? or can I just stick to the MCW60 only for cooling? I would have no plans to O/C.. but im also looking at the EVGA Ultra Black Pearl edition to make my life easier without having to mount a 3rd party heatsink. I am still deciding and it's coming to whether or not
The water temp barely goes up if you can believe it. Alot of the gurus on other forums have done testing and the temp of the water only raises a few degrees, <5C if I remember correctly. You will probally gain a few degrees if you run the system in series (cpu->vga) but it should still cool way better then an air cooler.
You absolutely need vga ramsinks on your card. Especially on the 8800 series since it has that I/O chip as well that runs really hot. If the stock cooler is cooling the ram, then you need to cool the ram as well. Your going to also have to have some kind of airflow over the card still to cool off the heatsinks.
Gabe, the owner of swiftech is currently using that 120 compact kit on his quadcore and 8800gtx. His temps aren't the greatest but his comp is quiet and stable. The 220 compact kit should work just fine; as long as you arent going for super low temps and/or a big overclock. Since your not overclocking the 220 rad will be more then enough.
