Hi,
I'm currently planning on building a new system that consists of a Abit IP35-Pro and GF 8800GTX video card.
I have been looking into water cooling over those big Scythe heatsink/fan combos.
my questions are:
1) A lot of people recommend going to Petra/DangerDan for introductory set up kits. But most of those are meant for OCing. What if I just want a quiet nonOC set up? Would the simple Swiftech/Zoolance kits be ok for that?
2) Regarding noise level, do you think it'll be a considerable audio difference going from air cooling to water cooling on the CPU, taking into account all the hard drives and GF8800GTX fans?
3) For my purpose, I'd like to just build a simple system where I most likely will not OC all that much. Do you think water cooling is a better solution for me? Or Should i stick to air cooling?
Thanks for the opinions
my questions are:
