A friend of mine's computer has no wireless card in it, but they want to remove the cables they have running along the floor.
She has a wireless router already.
She only had 1 PCI slot available.
It won't be a long distance, around 20 feet from the router. She doesn't play any games, the most she would do is stream movies from Netflix.
is it better to use a PCI card such as:
http://www.amazon.com/EW-7128Gn-150M...5187038&sr=1-4
or a USB adapter like this one:
http://www.amazon.com/Medialink--150...reless+adapter
those were just the first things that came up on amazon. Any advice on which type to buy or brands that are best would be helpful.
Thank you
Thank you
