Originally posted by: neonerd
Originally posted by: Skoorb
5.725 is the answer 🙂
what'd u use to get it?
He used the same equation you did.
You need to get your conventions straight at the start of the problem. If gravity is negative (or if it's positive but you have a minus sign in front of it), then your initial velocity is also negative.
In physics, it's all about setting the problem up right. It's all about thinking the math through and keeping your conventions consistent. Just remember that, and you'll do well.
