Yes.when you are at a stop light, do you put your car in neutral and just step on the brake, then when the light goes green hit the clutch, shift to 1st, and go.
Originally posted by: Zim Hosein
Normally, I put the car in neutral, and put my foot on the brake pedal till the light turns green jjyiz28 🙂
Originally posted by: Wuffsunie
Depends. If I'm sitting there a while, I shift it into neutral. Otherwise, just leave in first and have the clutch in.
same
