Question?-Please Read
mikef208
Banned
Nov 30, 2000
3,227
Okay I have a question. Upon reading reviews for the abit kt7a, I learned that abit has a new safety feature that will make the computer unable to boot if you do not have a fan plug into the CPU1 3 pin header, or if you do, and the fan is not working, registering 0 RPM, the computer will not boot. Well I have also read that some of the fans today will burn up a 3 pin header, so they include 3 to 4 pin molex adapters. If this is the case then how can this problem be solved. I am trying to make a quiet pc so my fan will likely not produce enough power to burn the header, but what about others that will. LMK what you guys think.
customride
4
if thats is the case then you could just plug in a small exhaust fan to make it happy! I have a kt7 and i have a delta fan on a 3 to 4 pin converter. i used the onboard one for my exhaust.
Renob
7,596
The 3pin on the Abit KT7 can handle the black lable delta fans I read this at some website cant remember the name. I have used the black lable no prob
