mfenn
I know that.
Maybe Windows has set it to PIO mode?
http://www.tomshardware.com/forum/147161-45-forcing-mode-primary-hard-drive
Yeah, that's what I was thinking.
I know that.
Question though, can I install the XP OS on my backup HDD withour reformatting it and losing all the data already on it. And will I also be able to partition it for the OS?
Dont put 7 on that hardware. Stay with XP.
Here's what I do, and what I recommend, for what it's worth:
* SSD as my C drive, has Windows and programs all that set up on it.
* Larger platter drive as my D Drive, this is where I store data and also make backups of my operating system to. Makes it easy to restore from if needed.
* External drive as my Backups location, I copy over all of my D drive onto it on occasion.
In the end I have everything backed up (C to D and D to External) and it's all pretty straightforward (at least in my opinion).
Dude, some bad advice on this thread. Some good, but some people didn't read your first post carefully.
This one in particular makes no sense at all:
"Dont put 7 on that hardware. Stay with XP. I would try putting a video card in there. HD3200 is a little long in the tooth. Try something like a 5450." Not only are you on windows XP that does only 2D rendering but your HD3200 is perfectly acceptable for displaying the desktop even on a brand new machine in 2013.
You actually don't need any new CPU or board. The X2 is a good CPU for your use case. I've seen plenty of Athlon X2 machines that run very nicely. I just built a bunch for family and friends as I upgraded my own computers and they were great machines. You have other bottlenecks.
Here's your problems:
#1 your HD is slow. This sounds like the sole reason you're having trouble. Fix this and your computer will feel fine again, but there are some good upgrades to make. Try using a new IDE cable. Your cable may be nicked or you might have used a 40 pin cable instead of the newer 80 pin cables. The 80 pin cables have very very small wires. My advice would actually be to get an SSD. This will make your system fly but you'll run into a problem when trying to move to the new SSD. You're old HD operates in IDE mode and your new SSD should operate in AHCI mode. You can't just ghost your old drive onto the new SSD and boot windows. It won't boot. Which brings me to your next issue
#2 Windows XP. Windows XP is a fine operating system and if you just fix your cable you're ok on XP, but if you are upgrading to an SSD or any SATA harddrive you'll want to run in AHCI mode which means you're reinstalling your OS and damn, in this day and age I wouldn't reinstall to XP but to Windows 7 or 8 and this is becasue of reason #3
#3 RAM. DDR2 is expensive but not more expensive than a new board and CPU. You can upgrade to 4GB of ram and be perfectly happy but windows XP will only see 3.5GB and your GPU will take some of that too (make sure you've set the GPU to use at least 256MB, 512 is best). That's still enough but not optimal for the future. You will want to upgrade to Win 7 64 bit so you can use the 4GB (this is enough) or 8Gb (this is probably overkill but nice to have) and Windows 7 is just plain better. It will have the AHCI drivers for your SSD already installed (You need special drivers to install AHCI on windows XP which means a floppy drive and disk at initial OS install) and it is just better...
That's it. Upgrade to a 128 GB SSD for your OS, use the old drive for extra storage, drop in some more RAM, and upgrade to Windows 7 64 bit and you'll be loving it. But, there are still some optional upgrades you can make. That board supports Athlon II class CPUs (make sure you have a BIOS that supports it) so you can drop in one of those Athlon II X4's at 3ghz for just $75 with 8GB of DDR2 and an SSD and you'll be doing great. The PhII people recomend is fine but it's a 125W CPU vs the 95W Athlon and honestly I don't think you'll be noticing any difference between the two except that the PhII runs hot.
Concerning #1: It is an IDE cable from 2009, kinda old. I wouldn't mind buying a SSD. Is there a setting to change to AHCI mode where I could install a fresh copy of XP on the new SSD? Then boot from there. And then install, somehow, my old 320GB IDE HD as data storage?
Concerning #2: Why not reinstall XP, I own it. I don't want to go out and buy a new operating system.
Concerning #3: If my system is slow because of the IDE HD, do you think with a new SSD that the @GB of RAM would be sufficient for my usages? Also, I'm using the onboard graphics, no GPU. What special drivers do I need for AHCI? I have to download them onto a floppy?
Thanks for all your help
Yep. That's almost what I do too. My D drive is a RAID-1 however to guard against disk failure. Backup is to a homebrew ZFS NAS.
This is the way I'm leaning right now. Although, I'm not quite sure how I set up a SSD and an IDE HD.
In XP, you just right click "My Documents" on the desktop and in the properties you type in D_:_\ (without the underscores, that's just to keep the forum here from converting it to a frowny face), and that's about it.
