- Dec 9, 2000
- 16,528
- 4
- 0
I am testing code I wrote for the automation of a sourcemeter to plot IV curves for detectors. The resistor I had burned out so I'm using graphite from a lead pencil I took apart. The current is a linear function of voltage (sourcing voltage, measuring current) up until about 300 volts, then the resistance increases, then apparently becomes negative, because from about 300 to 500 volts, the voltage increases, but the current decreases, linearly. After that, it starts smoking and open circuits...
I tried looking up some information and it says scientists have seen this in carbon nanotubes or something and on Wikipedia it says this is seen in some materials but I don't know, it's weird. I remember in class they said you couldn't have a negative resistance because it'd be producing energy (I think) and that couldn't happen but in our calculations you sometimes get a negative resistor when dealing with dependent sources.
Picture of a graph (bad one because this one isn't as smooth as the others): it's I over V, so it's conductance, but you can still see what I'm talking about
