Question, do USB cable modems suck?
vizionblind
390
I mean, tomorrow they come to install cable, but what if they only bring a USB only brand, like say a motorla.
Utterman
2,147
Usually when you have your cable modem installed, they use the ethernet port for the cable modem. USB does work with the cable modem, but does have more problems than a ethernet port would cause. The cable modem I have has both ethernet and USB, so you will prob. get a cable modem like that or just ethernet.
Sluggo
15,488
<< I mean, tomorrow they come to install cable, but what if they only bring a USB only brand, like say a motorla. >>
You are worrying yourself into a frenzy, just let them come and install the damn thing, see how it works.
NikPreviousAcct
52,763
<< Question, do USB cable modems suck? >>
YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES
They're a WORTHLESS PAIN IN THE ASS. I've been doing tech support. Listen to me. DON'T GET IT. DON'T LET THEM INSTALL THAT. If you need to, go buy a damn network card!!!
Nik
Thegonagle
9,773
Road Runner brought over a NIC and a Toshiba cable modem that supports Ethernet or USB. When he asked me if I just wanted him to try USB, I told him I'd rather have the NIC installed, so he didn't even bother with USB. The dude was super cool, so he even spliced a connection in for my TV and gave me a splitter, since my cable co. can't separate the data signal from the basic cable TV signal where I'm located, so I get free basic cable.
Electrode
6,063
I have a motorola cable modem leased rrom my ISP. It supports both ethernet and USB. When they installed it, they used the USB connection, but all I had was problems, the worst of which was that it doesn't work in Linux that way. First thing I did was head down to FS/FT and get a 10baseT card and a patch cable, now it works like a dream. :)
Long story short, ETHERNET OR NOTHING :D
Amused
57,547
20,261
Damn, Nik... don't hold back... tell us how you really feel!
Danman
13,134
I had a USB ADSL modem and it sucked hairy b@lls.......I wouldn't get it! :disgust:
punkrawket
1,924
the motorola sb3xxx and sb4100 (which is what i have) have both ethernet and usb, YOU CAN USE EITHER. you don't have to use usb
perry
4,018
Exactly. The guy that installed mine saw the custom built computer while he had the USB cable in his hand, then wisely put it back and got out the ethernet cable. I was afraid I was going to have to tackle him if he got any closer to my computer w/ that USB cable.
yakko
25,455
Well I don't think much of USB in general so I would get it. My Motorola has never even heard of USB.:)
