My Mazda is AWD and turbocharged.
Nothing goes over my head! My reflexes are too fast, I would catch it.
So what.. Even on SATA 1 there is huge difference in performance between ssd and hd. People who got really old laptops know that.I don't think an SSD will help much over a hybrid drive or a 7200rpm drive since the consoles use SATA 2 and not SATA 3
Modify this and it is applicable for every "wine aficionado" and "audiophile" I've come across, and completely proven wrong consistently.
While, in some cases, there are differences in graphics. In only edge cases are they large enough you will notice while playing. And even then, if it bothers you to have "inferior" graphics on your console, you're too elitist for a console. Put on your big boy pants and buy a few [latest GFX card] and a 4k monitor.
The CPU isn't fast enough in the consoles to make the big difference you see and expect on a PC. They can hook any drive up and at some point the drive is going to be waiting for the CPU to do work. That's why every article that talks about upgrading the PS4 HDD and comparing load times says the difference is sometimes non existent. You get the most gain on the XB1 by using a USB 3.0 HDD externally. Plus I think there is a ton more overhead on the consoles because of needing connected friend list, PSN and XBL connectivity to always be connected etc. Eats up some resources.
So I got a guy willing to sell me an Xbone with Halo 5 for around $200, which I consider to be an okay deal, especially considering the console itself is less than 6 months old.
I have been thinking about getting a console more broadly, and I'm aware that PS4 is generally seen as more powerful but my question is: by how much? If I want to play casual games like BLOPS 3 or SW:BF, is there any major difference? And how about the player base? I know that PS4 has a higher installed player base, but does that mean that there are difficulties finding games with lots of players on the Xbone for major titles 2-3 months down the line? (I'm not counting exclusives like Halo who have their own massive fanbase).
Thanks!
Wireless sucks anyway even on the Xbox one. Wired is better but honestly not by much with these consoles.
That's definitely not my experience. I use wireless through the xbox one and you can't tell the difference between wired and wireless. It's fast, snappy, and you can't feel any lag or lagginess in games.
I own both and I still can't get over how bad the Xbone UI still is. It's still convoluted and nothing is laid out cleanly. The PS4 UI isn't perfect but your games are right up front which is the most important part. Also the bumper buttons on the Xbone controller suck. They are much harder to press.
No, it's bad. My phone can pull 180Mbps from my wireless and the Xbox can't even sustain over 60Mbps on a wired gigabit connection. This means downloading games takes forever compared to what it should.
I have a 1TB Xbone which has the newer controllers with the headphone port and the bumpers still suck but the battery life is great and the sticks feel good.The new controllers fix that, I don't know if you have tried them. They are soft and almost too easy to hit.
My downloads on Xbone suck bad as well. I've tried some of the fixes I've read and nothing has sped it up to PS4 speeds which downloads everything fast. It was horrible trying to download Forza 6 and Forza Horizon 2 at the same time.No, it's bad. My phone can pull 180Mbps from my wireless and the Xbox can't even sustain over 60Mbps on a wired gigabit connection which is pathetic by comparison. This means downloading games takes forever compared to what it should.
