Question Question about USB port compatibility
Mtj
54
11
I'm looking to purchase a new computer and plan to buy a Gigabyte X570 AORUS Elite as a motherboard and a Fractal Design Meshify S2 as a case among other components.
Gigabyte X570 AORUS Elite has a Front USB 3.2 Gen2 Type-C connector and Fractal Design Meshify S2 has a USB 3.1 Gen2 Type-C connector at the front of the case. One of the reasons I like Fractal Design S2 is the type C connector, which in my opinion makes the case "futureproof".
Is it possible to connect the USB 3.2 Gen2 Type-C on the motherboard to USB 3.1 Gen2 Type-C on the case?
Should I look for a case with USB 3.2 Gen2 Type-C connector on the front, instead?
Thank you very much.
Insert_Nickname
4,971
1,695
Welcome to the weird and wonderful world of USB connectors.
USB 3.1 Gen 2 and 3.2 Gen 2 refer to the same thing (SuperSpeed USB 10Gbit). The USB Forum are experts at confusion.
Yes. The mainboard has a Type-E socket, so if the case uses a standard Type-E plug, it should fit as-is.
I don't think case manufacturers have gotten around to re-branding yet. So that may be futile.
Reactions: Campy
Mtj
54
11
I guess I might just get the P400S TG then. Thanks for your reply.
