- Jan 6, 2002
- 23,122
- 1,274
- 126
I Googled, didn't find anything that helps me. Neighbors Spectrum remote stopped working so they got a new one. I'm trying to help them set it up. Their box is in a closet down the hall and there's a long HDMI cable. I can't get behind the TV to check stuff out how everything's hooked up. I went thru the Spectrum remote menu, and I'm not seeing anything about CEC. If I open the closet and point the remote it controls the cable, if I try to do it from the living room the remote no longer controls the box. Since it worked with the old remote and nothing else has changed, I'm trying to figure out what I need to setup. The remote does turn the TV on and off and the volume of the sound bar.
I'm not finding anything on Google about configuring CEC on the cable box, but since the old remote worked I know it will work. Does anyone have a suggestion? I'm out of ideas. The box is a Spectrum 210t if that helps anyone.
