BonzaiDuck
- Jun 30, 2004
- 15,877
- 1,548
- 126
thanks, how much time did you invest in it? Tomorrow or rather much later today I'm going to drive to a shop to buy some TIM and clean both the cooler and the IHS and apply it fresh. I'm still not sure if I should buy some more IC diamond or some of that liquid metal stuff.
IF you use the CLU (liquid metal), just remember that it behaves a little like Mercury, which -- if dropped on the floor -- will splatter in little ball-bearing shaped parts. You don't want it getting on your motherboard, for obvious reasons.
The nano-diamond is non-conductive. It's maybe 1C degree less effective than the CLU. But another forum member and I shared our data to compare his H110i and the D14 (MY ducted D14). At the same VCORE and load-test (Prime95), we got the same temperature. Also -- lapping the IHS (invalidating the warranty and re-sale-ability) is worth a couple degrees, as would be lapping the nickel-plate off the heatsink base. All these little "grains of rice" add up.
The D14 really makes a computer case crowded and cramped. I think I could perhaps extend the duct to the front of the D14, or add a third fan where one of the original Noctuas in my photo is conspicuously missing.
I might have made the duct a tad "wider." But it draws air from the lowest D14 fin to the highest. Since all cases are different, the ducts would be different because of the alignment of the rear exhaust with the D14, or the distance of the rear tower from the exhaust fan, etc. etc.
You can purchase the art-board (black is a good color) at some arts and crafts store: 2'x3' panels are about $4+. They sell a three-part folding item of the same material for displays people might make for a class science project. It's cheap. To bend it, cut an eighth-inch-wide strip of the backing paper along the bend line. There are various glues that can be had for it, one type (Poly-Zap?) is about an ounce for $15; a cheaper foam-board glue costs maybe $3 or $4 and works almost as well.
It takes longer to do the measurement (precise -- in mm) and planning. If you make precise cuts and try not to make a mess of the gluing, it could take a Saturday morning while you watch cartoons on TV. . .
I figure it really gets a bang for the buck for making the D14 as effective as possible.
