- Sep 13, 2001
- 53,549
- 6,374
- 126
I was trying to take the door stops off my basement door so I could fit my new arcade game down the stairs, however the door stops look to be part of the actual door jamb. So I then pryed off the trim, and my actual door frame is about 1" away from the actual wood it is nailed to, with 3 1" shims spaced out.
So it got me thinking - why not just get a bigger door?
So tomorrow I'm going to rip the other piece of trim off the other side and hope that there is another 1" gap, although that may not be the case.
My current door is 30" and I would like to get a 32" door if I can.
However, the actual wood behind the frames, appears to be a 2x3 instead of a 2x4, which seems to be standard.
Do they make prehung doors that are work with 2x3 instead of 2x4? Or if I get one, am I going to have to either modify a prehung door, or just actually build the frame out myself to fit the custom size I need?
