Question about a case
NightOtter
19
I have a question about a computer case that more experienced builders might be able to help me with.
I would like to buy this Lian-Li case
http://www.newegg.com/Product/...x?Item=N82E16811112116
but I am worried about the side fan and the fan on the back being obtrusive to anything coming up from the motherboard. For instance if I wanted to add this
http://www.newegg.com/Product/...x?Item=N82E16835186134
would there be room for it?
I can't imagine that Lian Li would design something that would get in the way of common motherboard components.
Any reason for concern?
thanks.
Otto.
Zepper
18,998
That HSF is only 5" tall, so it should fit with everything in place. The A-C units are some of the more compact available. You might want to check out the OCZ Vendetta units as well - they are compact and very effective as well.
.bh.
