question about 2 channel system
TJ 2
84
Hey guys its been a while just a question, where do i connect my ipod jack into the back of my yamaha rs300b 2 channel receiver so I can play videos from my ipod through the TV? Any help would bd appreciated
kornphlake
1,567
9
Your receiver doesn't have any video connections, the dock linked above won't do any good. You need a new receiver or you need to find another way to connect the ipod to your TV. If your TV has composite connections (most still do) I'd suggest a cable like this: http://store.apple.com/us/product/MC748ZM/A plugged directly into the back of the TV.
fralexandr
2,289
229
www.flickr.com
hah I can't believe I forgot about that :\ i remember thinking that receiver was weird since it had no video inputs/outputs
depending on your TV, you can probably connect your IPOD to your TV and have the TV output audio to the receiver
this may also depend on what version of ipod touch you have
http://support.apple.com/kb/HT1454
in descending order of quality
if you have a TV that supports HDMI you can get an IPOD TOUCH 4th gen to HDMI female and an HDMI cable
http://www.newegg.com/Product/Produc...82E16858992233
http://www.monoprice.com/products/p...=10240&cs_id=1024008&p_id=4023&seq=1&format=2
if your TV has composite
else if your TV is really old and only has RCA
http://www.amazon.com/Apple-iPod-Aud.../dp/B000IJ73OY
TJ 2
84
Thanks for the advice guys connected the advised iPod dock to the receiver via the cd port I'm getting sound and video thanks for the advice, was quite impressed with the sound from the rs300 with the wharfdale at400 speakers and the 150 wharfdale diamond sub, for a standard package it does well
TJ 2
84
Can anyone explain to me crossover frequency? Ive just updated my sub to the wharfdale 150 diamond and i havnt owned a sub with this option at the back of the sub and im not sure what setting to have it on and i cant help but feel im not getting the best out of it? Any advice would be appreciated.
fralexandr
2,289
229
www.flickr.com
crossover frequency is the frequency at which you want the receiver to send data to another speaker or driver, in this case the subwoofer
generally crossovers for subwoofers are set to around 80-100Hz, but if you're using smaller front speakers (i.e. energy micro) you might want to set it a bit higher (i.e. 120-150)
usually this is set on the receiver
does the wharfdale accepts speaker output to the front left right?
if it does, then that's probably how the crossover is set when connecting speakers to the subwoofer directly
TJ 2
84
Ok so because my speakers are connected to the receicver me setting the crossover on the sub will make no differance? Also just wondering with my sub being front firing is there a best place to position it? Im just not happy with the performance? it is a big upgrade from my last sub and is suppose to be a good one its a wharfdale diamond SW150BAV?
sdifox
100,504
17,956
you set the crossover on the receiver and then on the sub you set it to the highest it will go thus nullifying the low pass filter on the sub.
placement depends on your room. try corner if you think it is not putting out enough oomph.
TJ 2
84
Is there any way I can hook an old realistic graphic equalizer up to the yamaha rs300 2 channel reciever? And if so how??
TJ 2
84
Also in regards to the wharfdale sw150 diamond im not sure if i have it connected right, i have it running from the pre out sub jack at the back of the receiver but there are 2 red and 2 yellow jacks that look like they are for speakers? Where should it be connected? I dont understand as alll the previous subs i have owned only have one place for connection
