Keysplayr
- Jan 16, 2003
- 21,219
- 54
- 91
Originally posted by: TheSnowman
With a clean running system, what little else you have on in the background windows will place comfotably on your swap file. so if the game itself doesn't use any more than the 900mb I have seen it take then a well managed system will run it just as well with 1gb as it will with 2gb or more. It is only when the actively working processes need more ram than you physically have that you will see swapping.Originally posted by: keysplayr2003
It was probably total system usage. Mine is pegged at 1.3 GB when playing fear. So, with the OS and all memory resident programs running (anti-virus etc.etc.) plus FEAR running WILL result in disk thrashing (page file swapping) which causes massive stuttering. I switched to 2GB and FEAR is as smooth as butter with all options maxxed of course. 1280x960 on a 7800GTX. With only 1GB the game bordered on unplayable at the settings I desired because of the VERY annoying and constant stuttering. 2GB is the answer for this game. At the very least 1.5 GB.
No, it will not. Even with the cleanest windows XP install, and just antivirus (everyone should have antivirus no matter what) Windows will utilize anywhere from 100 to 125MB of system memory and that's being conservative. Add the 900MB for FEAR, and your right over the 1GB mark.
Snowman, I know this because thats exactly how I had my system because I got real tired of the stuttering. I took a fresh hard drive (400GB) and Installed WinXP and Antivirus. Then FEAR. FEAR stuttered less than before, but still stuttered almost every damn corner I turned and every new room I entered. It even stuttered just before enemies appeared, so I knew when they were coming using the stutter as a signal. I couldn't take it anymore and stole 1GB of my music studio PC and installed it into my gaming rig. No more stuttering, at all. Not even once. Most pleased.
Please don't try to tell me that I did not experience this. That would be just silly.
