Engines
A Rolls-Royce Trent 900 engine on the wing of an Airbus A380
The A380 can be fitted with two types of engines: A380-841, A380-842 and A380-843F with Rolls-Royce Trent 900, and the A380-861 and A380-863F with Engine Alliance GP7000 turbofans. The Trent 900 is a derivative of the Trent 800, and the GP7000 has roots from the GE90 and PW4000. The Trent 900 core is a scaled version of the Trent 500, but incorporates the swept fan technology of the stillborn Trent 8104.[101] The GP7200 has a GE90-derived core and PW4090-derived fan and low-pressure turbo-machinery.[102] Only two of the four engines are fitted with thrust reversers.[103]
Noise reduction was an important requirement in the A380's design, and particularly affects engine design.[104][105] Both engine types allow the aircraft to achieve QC/2 departure and QC/0.5 arrival noise limits under the Quota Count system set by London Heathrow Airport,[106] which is a key destination for the A380.[14]
The A380 was used to demonstrate the viability of a synthetic fuel comprising standard jet fuel with a natural-gas-derived component. On 1 February 2008, a three hour test flight operated between Britain and France, with one of the A380's four engines using a mix of 60 percent standard jet kerosene and 40 percent gas to liquids (GTL) fuel supplied by Shell.[107] The aircraft needed no modification to use the GTL fuel, which was designed to be mixed with normal jet fuel. Sebastien Remy, head of Airbus SAS's alternative fuel programme, said the GTL used was no cleaner in CO2 terms than standard fuel but it had local air quality benefits because it contains no sulphur.[108]
An engine on a Qantas Airways A380 en route to Sydney, Australia from Singapore fucking blew up mid-air. [109]
