Originally posted by: jjrowley
bumpity bump, what stress test do I run to see if I can change the tRD from 13 to 10 and survive it? Memtest?
I tried your OC n7 and crashed 15 min into it. LoL, these damn chips are like dating sisters, just because there manufactured at the same place doesn't mean you get the same thing.
Ok this doesn't make any sense. I decided I was just pushing it to far and backed it up a bit to a 3.8 or so OC. Stable. Got tRD set at 10. For shits and grins I upped the FSB to 475 with vcore at 1.4 and it went in.. it never went in with higher voltages or with this lower tRD. hoping for the best, question: when I run memtest how many copies should I run? Everest is showing me 2896MB of free memory atm so I was going to divide that by 4 and run 4 copies of it, does that work? Or should I divide by 2 and run 2, or just run one, and test the full 2896? gonna run IBT in the meantime to see if it will actually stay stable. Also I haven't touched GTL at all. I keep reading about how theres not enough accurate information about it so haven't bothered.
Getting close to being 24 hour stable with prime!!! Will run memtest overnight next if all is well and post back screens and results if all goes well. Stay tuned..
Oh, before I get to the memtest part, you said run 4 copes at 500mb per instance, from my understanding of what I have read Vista uses x amount of ram at any given time but the ram it is using is constantly changing, using different parts in other words, so is this why you suggest 500mb per instance and eventually if allowed to run long enough, such as overnight, it will cycle through all of it reguardless of the 500x4 not being what it lists as available, other threads I have read suggest shutting down everything that doesn't need to be running during the test, then opening whatever monitoring programs you plan on using while it is running, finding what is available and dividing this number by four to determine how much each test will run. If I understand how it works, then either method should do the same thing right? What is the benefit or con of only doing 500 as opposed to say 755 each test? Not trying to say one way or the other is right, but as the 2 old sayings go "Knowledge is power" and "Now you know, and knowing is half the battle"
well I don't know what happened with the prime 95 not staying running, but i suspect I didn't have it set right, because after 14 hours it shut itself down, log says everything passed, and I noticed when I open it up I have it set to run 4 torture test threads, so I assume it ran these four and stopped? blah, i'll run it another 24 hours, but for now heres where I'm at.
CPU-Z Validation page
http://valid.x86-secret.com/show_oc.php?id=442450
CPU-Z actually showing v-core
http://i83.photobucket.com/alb...esserowley2000/014.jpg
memtest
http://i83.photobucket.com/alb...esserowley2000/013.jpg
the beast
http://i83.photobucket.com/alb...mputer%20Build/008.jpg
high 40's low 50's. I saved that OC profile in my bios and started a new one actually. I kept reading all kinds of stuff about the 45nm chips and voltage, so I'm going to see how I can do at 1.3625 the recommended safe cap on this thing. Right now at 3.867 with 455 FSB. gonna run some prelims and make sure its stable then I'll run an overnighter when I find the cap at this voltage. will post back with results.
Originally posted by: Big Lar
I've been messing around a bit with the cpu margin setting thingy and have found that I am doing a bit better with Compatible versus Optimal of which I was running. Not much diff yet but I picked up a coupla fsb without raising the cpu voltage so far. More testing in the works.
Larry
Larry
Hmm truehighroller on XS was suggesting that was well...i'm gonna have to try it.
I have gotten VTT to 1.34 w/ GTLs @ 0.68 each now for 8.5x465, & NB down to 1.36.
Still not done though...
