Gillbot
- Jan 11, 2001
- 28,830
- 17
- 81
Originally posted by: n7
PCI-e @ 101 is an old trick that was used when some older boards didn't lock it properly @ 100.
It's so common (though usually totally unnecessary) that even i do that...it's just a habit for many i think.
On newer boards, there is no reason there should be any difference between 99 or 100 or 101...
As for the OP...FSB limitations
This is why low multis suck.
His chip obviously has a lot more in it...but it needs a higher multi to get there.
Yep, it could be 100% in my head because I usually make so many changes that it's hard to keep track.
Side note Big Lar, did you try the 400 strap on your Q? I got a P5QL-E sitting here that isn't treating me well. It's rather fickle with settings as opposed to my MSI.
