Originally posted by: Idontcare
Originally posted by: A554SS1N
Would a 400FSB be safe for the long term on a board like the Gigabyte DS3L? I'm thinking of maybe now going quad rather than dual (previously I was strongly thinking of an E8400), and just getting one of these Q9300's to around 3Ghz, which would be acheived via 7.5 x 400Mhz. Ideally I'd want to keep things for a while, so I wouldn't want to kill the motherboard in a couple of years. Also, would 800Mhz RAM be fine and what kind of divider/multiplier(?) would be needed?
My ambient room temp would never go any higher than 27C degrees in summer, and at the moment is sitting at a cool 16C degrees! 😉 (if that info helps at all)
Thanks in advance.
In addition to what Aigo said above in response to your post I will add the following "data" regarding my specific experience with the DS3L.
I replaced the TIM under the stock NB and SB heatsinks. I used AS5 on one. TX-1 on another. Ceramique on a third. And TX-2 on yet another.
I also (yes this is silly) lapped the stock NB and SB heatsinks and then used TX-2 with that board.
The end result? All 5 DS3L boards top-out at around 367MHz FSB for me. This is with Q6600 and mild NB voltage bump. I lowered clock multiplier to confirm I was truly FSB limited and not CPU limited.
I am sure I could have pushed voltages to get higher FSB, but this seemed to be the sweet spot for my boards.
Now I did not go the extra mile, as Aigo nicely outlines, and replace the meager stock heatsinks with aftermarket heatsinks. I also did not add any extra cooling to the MOSFETs. I do have pretty decent airflow thru the case though, 2x120mm intake and 2x120mm fans on the exhaust.
Just to set your expectations for DS3L with moderate effort to "prep" for overclocking. Aigo recommendations are the way to go to get anywhere near 400MHz FSB on a DS3L in my opinion.
