Q6600 vs Q9550 OC'd
SPBHM
5,068
423
If there had been an i3k version I probably would have jumped on that and OC it all the way, a friend has a 2500k and he can reach 4.5 on stock cooler and stock volts completely stable
I totally agree, being able to OC the i3 would change a lot, and now with some competition from AMD (FX 6300 looks pretty good compared to what Intel can offer on the sub $180 segment) and a new platform (lga 1150) this might be a reality again, there has been some reports that Haswell will have some BLCK overclock headroom, which would be great for the lower end locked parts I think.
rbk123
748
351
The G0 stepping of the 6600 easily reached 3.4-3.6G with minimal volting. If it's a G0, I'd save the $35 since both are old tech and the performance difference between the 2 will doubtfully be noticed.
Ketchup
14,559
248
My last CPU was a GO 6600 that would reach 3.6. It was a furnace, but fast. Very happy with it.
SPBHM
5,068
423
easily?
my G0 would hit easily 3GHz, but for more than that needed good cooling and overvolt, and and at that stage my cheap MB couldn't handle the power usage anymore.... also the q9550 can go significantly higher, or use a lot less power for the same clock.
but about the rest, you are probably right
this can be useful
http://www.xtremesystems.org/forums...eb-vs-intel)&p=3552100&viewfull=1#post3552100
2is
4,281
131
I've built at least 4 G0 machines. 3 of them wouldn't hit 3.6 GHz at all, and the one that did, didn't do it easily at all.
rbk123
748
351
Yes easily. A search on G0 6600 on this site, or google it, and you'll see the easy majority hit 3.4 to 3.6. G0 was the stepping to get. I still run mine at 3.6 and it's now 4.5 years old. As for needing "good cooling" - most were using something inexpensive like the Hyper 212+. No one is silly enough to claim 3.4-3.6 with the stock cooler.
2is
4,281
131
I don't need to search, I was around when G0s were all the craze, and you're wrong.
xcal237
98
i was running a Q9550 @ 3.5 ghz @ 1.12 vcore before i upgraded to a 2500k it was good for most games but bf3 required more power
Triglet
260
I'm running the rig in my sig and that chip has been a champ. In BF3 @ 19x12, Ultra, 4x MSAA, 16 AF I'm getting similar frames as what's shown in Anand's Bench (around 60-70). In game, I'm around 75-80% CPU usage when the card is pegged at 99%.
If you can get it overclocked high enough it's a good chip. Sure I'm probably losing some compared to the new platforms but whatever, not worth the cost to upgrade as of yet.
Yuriman
5,530
141
I upgraded from a Q6600 @ 3.0 to an overclocked i5 and it was night and day in a few games - namely Guild Wars 2 and Starcraft 2. Others showed no improvement.
I'd say 775 chips still have a bit of life left in them but they're showing their age.
2is
4,281
131
So for you, the q9550 wasn't enough to run bf3 at your resolution?
Resolution has little to do with CPU. "enough" is a very relative term also. You can certainly get by on a 9550 and BF3, but if you want to maintain at or near 60fps on a full 64 player server, it's not going to happen on a Core 2 Quad. If 45 fps is good enough then you should be fine with a Core 2 Quad clocked at >3GHz
Stickmansam
44
Well i plan to play at 1080p and the 7850 hits arround 45 ish there anyways so i guess this is a good match for cpu and gpu?
Yuriman
5,530
141
You can check your GPU utilization with programs like GPU-Z. When it drops below 100% you're bottlenecked by something else.
lowrider69
422
Get the Q9550. I went from a e6420 to a Q9550 about six months ago and I don't regret it. I was going to do a total system overhaul, new board, CPU, etc..and I decided that it wouldn't benefit me for what I do. I run VMs and do some gaming @ 1920 x 1080 on 24" monitor and I have no complaints. And I only have a GTX 550ti that I bought for $100 or something. I don't play games that often but when I do it's very smooth.
Sparkion
40
In my enperience, overclocking on the q6600 works very wel. I've mine running on 3.23 Ghz and it''s undervolted.
Either i got very lucky a couple of years ago, or i got a great board. (its a dd3 board btw).
Still.. if u have the money, go for a newer socket with an I5 for example.
(because my q6600 is still bottlenecking my graphics card a bit) this is purely explainable due the difference in age/ generation diff between cpu and gpu.
