GarfieldtheCat
- Jan 7, 2005
- 3,708
- 1
- 0
Originally posted by: Markfw900
Originally posted by: jaredpace
for overclocking:
q6600 > q9450
QFT
I don't think it is that clear-cut.
From what I have seen ( I have only a Q6600 @3.5GHz), it depends on what you want.
"easy" overclock (IMO, ~3.2 - 3.5Ghz) -> Get a Q9450....it will be cooler, don't need a lot of cooling, should be pretty easy to get on most decent motherboards. You aren't trying to max out your OC, just get an easy performance bump.
"hardcore" overclock (IMO, trying to max it out, maybe hit 4GHz or close to it) -> Get a Q6600, the higher multi will help, can use a bit more voltage, but will need more expensive cooling (high end air or water).
I think it depends on what you want to do and how much time you want to spend on it.
