- Jun 24, 2001
- 24,195
- 857
- 126
I've been told to aim for 3.0-to-3.2GHz to reduce bottlenecking my GTX280 and 9800GT (for PhysX) in my Asus P5N32-E SLI PLUS (limited quad-core upgrade options).
I know the Thermalright U120E is pretty much the best air cooler, but I paired it with the same super-quiet fan it was reviewed with here on Anandtech. If I go for 3.2GHz, should change the fan or is this OC easy enough to obtain without doing that (considering the cooler)?
As it stands, it's all in a loud Antec 900... as if the GTX 280 and PC Power and Cooling TurboCool 1KW weren't loud enough already! Should I just crank up the speed on the A900's fans and leave the same CPU fan mounted?
