So in December I built a new rig going from a CD2 Laptop with heat issues hoping to get away from it. It didn't happen.
XPC SP35P2V2 Barebones
Q6600 [Non G0, Not overclocked]
4GB GSKILL PC6400 Ram
300GB WD VelociRaptor [OS / Apps]
1TB Hitachi Ultrastar 32MB [Backup]
Asus EN9600GT Silent 512MB [Linky
So at idle, this thing runs at approximately 46*C
Using the XPC Tools and fans on full [sounding like small aircraft in the room ready to take off] it idles at 42*C.
I was wondering if possibly finding a G0 stepping CPU and perhaps a GPU with a cooler that would still cram into this box would really make a difference. Or just switch to a full tower. Room temps are normally ~70*F. Unfortunately after the rig runs for 30mins, that temp reaches up to ~78* or possibly higher. This PC was used as a furnace in December for my appartment. It never locks due to heat, but the amount it puts off is insane.
All I'm looking for is a rig that can browse, do some media apps, and the occassional WoW or what have you. Any suggestions would be appreciated. In any route.
Thanks.
Thanks.
