[Q] Have 2500K Maybe I7 950 as a Replacement?
Eddie313
634
Just had a question I have a Intel 2500K And use all sata ports.
I wanted to know Vs I7 950 Maybe as a replacement ? I have seen some of the reviews on here and 2500K beats them but not by much. I spoke with the place that i got the sandy bridge from they said just return the mobo/cpu/ram. I dont want to want 2 months for a motherboard. How much of a step down do you guys think it would be for that
Intel Core i7-950 3.06GHz Boxed Processor
Asus Sabertooth X58 LGA 1366 X58 ATX Intel Motherboard
Ballistix 6GB DDR3-1600 (PC3-12800) Triple Channel Desktop
Thanks
OCGuy
27,224
37
Nothing wrong with these chips, you should go for it.
My guess is that you would not be able to tell the difference.
Sp12
799
Why not grab a Sata card in the meantime? I would still pick SB over X58 for the overclocking and new features.
Eddie313
634
I thought about getting SATA controller thing I'm worried about is getting a refurbished motherboard.
smakme7757
1,487
In all honestly you can abuse all the sata ports for a year and never notice any problems. You would be fine until April, just send your board back to the shop when they recieve stock to make the change over.
Krynj
2,816
8
Yeah, just hang onto your current parts until there's enough stock to replace your board.
No reason taking a step down (no matter how slight) to older parts, when your Sandy Bridge build will be fine until you can get a replacement.
Eddie313
634
I use the crap out of my computer and don't to get errors or data loss. Does anybody know if the replacement boards will be new or refurbished???
Zargon
12,218
gigabyte is claiming they are going to give out NEW motherboards. dunno about MSI.
Krynj
2,816
8
Well look at it this way. If you go back to 1366, you're going with old (but still powerful) hardware. If you're a heavy user (which I'm betting you are), why not just stick with Sandy Bridge and superior CPUs?
The least you'll have to do is swap out your board with a free, non-defective replacement. If your board does fail, it's not even expected to within 3 years, and even then you'd have to own one of the 10%-15% of boards that will fail.
Your system will be fine until your manufacturer offers you a free replacement. You have nothing to worry about.
Eddie313
634
I just got off the phone with MSI they said they will replace it with same spec or better and it will be a brand new motherboard. Also they said the shipping will be free.
Only thing i have a problem with is how long shipping and if they do not give me the same motherboard i will have to reinstall my operating system again any ways.
I'm on the fence about the hole thing.
Nintendesert
7,761
Unless you're seeing problems and having issues you should be fine waiting for the replacement motherboards to ship.
Eddie313
634
Well started backing up my data to my back up drives inside the pc guess i'm one of the un-lucky ones. Most of the time its hitting 1mb per sec.
StinkyPinky
6,992
1,284
Geez some of you guys are panicking a bit too much. It's 5-15% over THREE years. The chance of your sata ports dying within the next 2 months is very low. Hell, odds on you can use it for its natural lifespan and never have a problem. Just relax and wait until you can RMA.
Eddie313
634
Did you not see what speed i'm hitting on my ports? around 1mb to 15mb on transfer.
Yes i do but have all the sata ports filled right now.
Krynj
2,816
8
Do you have SATA III drives?
And what happens if you transfer single large files? Like, files over 6-8 gigs.
Eddie313
634
Yes But i have all 6 ports being used.
I'm just going to go with the I7 950 I do not want to want 2 weeks for a rma and have the system down in that time.
I know its crazy but i almost never rma a product just because of down time and having to deal with the companies. I have had many bad times with rma's.
Bryf50
1,429
51
Your speeds seem pretty normal for what your doing. Many small files transfer much slower then a single large one.
Eddie313
634
I have a Q9550 system also and I hit around 80MB per second on data Transfer.
