Originally posted by: BW86
"Fridge Adventures"
Originally posted by: 1Dark1Sharigan1
NOT a good idea . . . lol . . . also drilling holes in a fridge? Can anyone say "wasting electricty?"
Can any one say, it will destroy your fridge??
HDD's are the biggest worry, condensation on the platters can cause the needle to slip. You dont want that happening.
I think the best solution is water cooling with the resevoir / radiator in the fridge, and have your tubings insulated with some grade A stuff, and your golden.
Originally posted by: BonzaiDuck
If you could get your cold-plate(s) and heatsink(s) inside the water reservoir, with the hot-plate(s) and heatsink(s) outside the reservoir, then you only need to find a way to vent the air through the hot-side heatsink(s).
And you probably wouldn't need a radiator, or you would've turned your reservoir into something like a radiator, anyway. . . .
Originally posted by: Bushman5
their are stuff u can spray the motherboard ect with that would protect it from water. 2nd idea would be to submerg all the part in oil
Originally posted by: Greenman
Condensation will only form on a surface that is COOLER than the air. It won't form on WARM computer parts in a fridge. I can't understand why so many people can't grasp that. When you run the AC in your house does condensation form on the walls and ceiling? Go try it, I'll wait .............................................................................................................................................................................................................
See, the house gets cool, and water doesn't run down the walls. If you go look outside you will find a little tube with water driping out of it, that's condensation that formed on the COLD AC coils.
Condensation forms on the ceiling or walls of the fridge, collects into large and larger droplets, forms an actual drop of water which drips onto your PC and we all know what happens next.
By all means, try if your way, preferably on an older machine and see what the results are but I think you are the only one on your side of the fence in this situation.
"Fridge Adventures"
